Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My L100 Sabre is 4 years old and has always started and run well. Every spring I do the annual tuneup kit. The end of last year the mower would start but when I added throttle the engine would run rough, have difficulty accelerating and pumps out blue (fuel) smoke. I checked all the fuel lines up to the carburator and found no obstructions although there is a little dirt in the tank I don't believe this is the problem. The plug sparks properly and is clean. Can you help?
  • 29 Answers
Blue or white smoke is oil or water. Fuel smoke is black. The rough running is dirt in your carb.
Posted on May 01, 2010
Ariens snowblower won't start
Did you drain the gas from last year? Gas is only good for a few Months. You should always run the machine dry at the end of the season or add Fuel Stabilizer at the end of the season. Id start by getting all the old gas out of the tank and the fuel Bowl on the carburetor. You will also want to check for spark. to make sure there are no electrical issues. Check oil level also. Depending on machine it may not start if oil level is to low alot of machines have a oil pressure switch.
Dec 14, 2013 | Garden
Snowblower won't start this year. Machine
Did you run the engine for about 15 minutes after you added the fuel conditioner? If not then the conditioner didn't get into the carburetor and you probably will need to take it apart and clean it again. The ethanol in today's fuel causes problems in carbs that sit
Jan 20, 2013 | Garden
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
On the Sharp EL-738 calculator, how do I find the interest rate? The question is: Jane earns $300 interest over four years on her investment of $1,200. What annual simple interest rate does this...
Jane starts with 1200$ at the beginning of the first year, and at the end of the fourth year she has 1200$+300$=1500$
Use x for her annual interest rate, that means at the end of the first year she will have 1200$*[(100+x)/100]. At the end of the second year her first-year money earns at the same rate, so she will have 1200$*[(100+x)/100]*[(100+x)/100]=1200$*[(100+x)/100]^2 at the end of the second year.
At the end of the third year she will have 1200$*[(100+x)/100]^2 *[(100+x)/100]=1200$*[(100+x)/100]^3
At the end of the fourth year she will have
1200$*[(100+x)/100]^3 *[(100+x)/100]=1200$*[(100+x)/100]^4 which is equals to 1500$
1200$*[(100+x)/100]^4=1500$ divide both sides by 1200$
[(100+x)/100]^4=1,25 take the fourth root of both sides
(100+x)/100=1,05737 both sides*100
100+x = 105,737 both sides -100
x=5,737
So Jane's annaual interest rate was 5,737%.
Hope it helps you.
Mar 10, 2011 | Sharp EL-738 Scientific Calculator
Ali decides to invest a certain sum of money in business at the end of each year in the form of an annuity. He wants to get a sum of Rs.40, 000 after 20 years. If the payments accumulate at expected profit...
Ali decides to invest a certain sum of money in business atthe end of each year in the form of an annuity. He wants to get a sum of Rs.40,000 after 20 years. If the payments accumulate at expected profit of 8%compound annually, how much should he start investing annually?
Jan 13, 2011 | Health & Beauty
Ali decides to invest a certain sum of money in business at the end of each year in the form of an annuity. He wants to get a sum of Rs.40, 000 after 20 years. If the payments accumulate at expected profit of 8% compound annually, how much should he start investing annually?
Jan 12, 2011 | Health & Beauty
Want start. Lawn mower is about 4 years old. Because of my health I have not used it in about 2 years. When I last used it it worked greatbut now it want start. I put gas oil and a new spark plug on it but...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 19, 2010 | Poulan Pro 22" Self Propelled High Wheel...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
380 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
