Question about Palm Treo 600 Handheld
Dead treo 600
My treo 600 hanged and I tried to reset it. the power just went off and I cannot turn it on anymore. Help!
  • 4 Answers
Plug in the battery charger, and it should start.
Posted on Apr 12, 2008
Palm Treo 600
Do a hard reset by holding down the K and return key, and at the same time push the reset button on the back. Plug in the charger to turn it back on. You can then start over by selecting english.
Apr 04, 2008 | Palm Treo 600 Handheld
"not enough power to activate wireless mode" problem for treo 600
call to your wireless provider and they will help you turn it on
Apr 03, 2008 | Palm Treo 600 Handheld
Hard reset
hold K, return key, and press reset. reconnect charger to turn back on.
Apr 01, 2008 | Palm Treo 600 Handheld
Palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
Feb 07, 2008 | Palm Treo 600 Handheld
Palm One Sprint to Cricket Treo 600
This is a problem with the Treo 600's, because the phone is starting to get old and isn't compatible with some gsm providers anymore.
When it is happening, perform a soft reset (push the reset button on the back). Occasionally this helps, but NOT all the time.
Your best bet is to upgrade to a later model treo, like the 680.
Nov 27, 2007 | Palm Treo 600 Handheld
Palm treo 600
It sounds like you have a bad battery initially, but your other issues may point to a software issue or something else. Have you tried a hard reset or updating the firmware on your palm? You can go to the Palm website and click on support and then choose the TREO 600 and the provider (Sprint, Verizon, AT&T, etc) to get the firmware updater. You will also find a User's Guide with instructions on how to hard reset the device. These two options may help you with your problem.
Oct 25, 2007 | Palm Treo 600 Handheld
Palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    Sep 22, 2007 | Palm Treo 600 Handheld
    Phone Freezes
    If you mean that the phone hangs for a couple of seconds and then hangs up the call - I think I found your solution - My Treo was doing the same thing - so I just reseated the battery connection and it fixed my problem.
    May 30, 2007 | Palm Treo 600 Handheld
    Phone hangs when connected to charger
    Sounds like a problem with the battery. Is it a problem to make a telephone call and do you have a humming noise?(gsm sound)?
    Jan 03, 2007 | Palm Treo 600 Handheld
    My treo is doing hard reset automatically
    try performing a battery will reset the internal radio and the charging circuitry..only problem here is that u need an AC charger to switch the phone back on. this will wipe out all data u may want to back it up before trying this option heres how to do it Battery Disconnect Reset Treo 600 only A battery disconnect reset is a last resort step you can take to cut battery power, wipe all data, and regress a Treo 600 to its factory-fresh state. It only works on a Treo 600 smartphone. Important: A battery disconnect reset will erase everything on your smartphone, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything. You won't be able to turn your Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset without your Treo 600 charger and a power source. HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost. To perform a battery disconnect reset: 1. Disconnect your Treo 600 from the AC charger. 2. Hold down the K and Backspace keys simultaneously. (Note: for French AZERTY keyboard, press K and M; for other language overlays, please refer to the customer support for your region) 3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device (where's the reset hole?). 4. Finding it hard to do? Good. We made this type of reset very awkward to perform, so that it would not happen by accident when your Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to ask a friend to lend a hand if you find it too difficult to do by yourself. 5. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens. Your Treo will appear to be "dead" and the screen will not turn on. If you see any activity ? such as the screen turning back on ? the reset was performed incorrectly; try again 6. To revive your Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging. 7. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is an extended type of hard reset).
    Aug 06, 2006 | Palm Treo 600 Handheld
    Palm Treo 600 Handheld Logo
    47 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
