Question about Precor 9.21 Treadmill
Wax or silicone on my 10+ year old Precor M9.21
Should I use wax or silicone on my 10+ year old Precor M9.21?
  • stormy663 May 02, 2010
    applied to the belt or the deck? I ask since wax is normally applied to the deck.
  • mddonnell Jan 19, 2013
    how do you replace a walking belt on M9.1
  • 83 Answers
Use silicone to lube your treadmill.
Posted on Apr 30, 2010
  • Ben Winton
    Ben Winton May 03, 2010
    Lift the edge of the belt on one side and apply the silicone between the belt and deck. Then do the same to the other side. Once you have applied the silicone, walk on the belt to help spread the silicone on the belt.
    Problem Solver:
  • 14 Answers
Precor belts are silicone belts NOW. Your treadmill is WAX. If you look at the backside of the deck (facing floor) you will see a wax coating! Use Landice slipcoat!!! I am an authorized Precor Tech. Silicone would be used on any of the new units. Not yours!
Posted on Apr 09, 2011
  • Precor Master
  • 914 Answers
Video of How to Lubricate a Treadmill using Liquid Lube
Video about How to Lubricate a Treadmill using Liquid Lube
  • This vidoe will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes todays demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video
Posted on May 12, 2014
Does this norditrack use wax or silicone lube
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am assuming you have never waxed your machine before. If this is the case, you should be safe using the liquid silicone lube. When this becomes an issue is if you were using the powder wax and tried to change to a silicone liquid. It would still work, but you would, more than likely, end up with some wax build up on your rollers.
Jan 05, 2016 | Exercise & Fitness
I have a precor 92.1i unit and it is emitting black dust from the back left quarter. I have inquired at the store where I purchased the unit several years ago and they advised me that there had been
If you really have a 'black dust' issue, your machine would be at least 7 years old - if it is less than 10 years, the parts would be under warranty, assuming you bought it new. One or both rollers and the walking belt would need to be replaced. You were advised to call Precor - did you? I am surprised the retailer did not offer any help - this seems like poor customer service.
Oct 14, 2014 | Precor Exercise & Fitness
Precor c965i won't maintain speed the more weight on it
weel you must read the specification of your model, what is the maximun weight that is acceptable. However you must LUBE the deck belt with silicones or wax , read your owner manual for this, and execute inmediately.
God bless you
May 29, 2013 | Exercise & Fitness
Hello, Our Precor 9.21si begins slipping after walking or running a few minutes. Seems to be worse the faster you go. After about 1 mile, the house fuse blows. What troubleshooting steps do you thi
This really sounds like the results of long term use without lubrication or wax between the belt and deck. Chances are you will need to replace the running belt and the deck or flip the deck if it has not already been done. The friction builds up between the deck and belt and caused the electronic components to overheat. The machine is shutting down as a precautionary measure. It will do this only so many times before the electronics are zapped. Start with the deck and belt. Hopefully the electronics are okay. With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
Feb 03, 2013 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Precor C966i The unit turns off at random intervals. When reset it comes back on then shuts off a few minutes later. Error log is empty so not an error with software.
LUBE or wax the deck belt, this happen because you do not lube or wax your equipmente according with the schedule maintenance, you must do it, every week. Do it now.use 100% silicone lube-
2) LUBE the rollers bearing too use WD-40 for rollers b only.
3) Test the drive belt motor, and adjust it or replace
4) test the input voltage motor, if there are the motor need repair.see my personal TIPS for troubleshooting helps.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Nov 13, 2012 | Precor C966i Treadmill C 966i
After walking for 10 minutes or so, or even sooner when I am jogging, the 921 loses power and trip my house circuit breaker. What needs to be replaced? Guessing it is the power cord as the 921 is 20...
Check your Amps on the circuit that is being tripped. The treadmill needs 15 Amps to run. If you have a 15 Amp circuit that is running the treadmill and other electronics (or lights), the circuit will trip. You may need to replace the circuit with more Amps.
Mar 02, 2011 | Precor 9.21 Treadmill
I have the Precor 9.31 and it is 4 years old. When I start going fast the power shuts off completley. I am 210 pounds and this happens to me, however my wife is 120 pounds and is not having a problom.
SOUND LIKE A LUBRICATION ISSUE DEPENDING ON THE MANUFACTURER NOW A DAYS SYN SILICON IS USED ON MOST PHENOLIC DECKS IF NO MAINTENANCE HAS BEEN DONE I WOULD ALSO CHECK THE FOR UNEVEN SURFACE AND THE BELT MAYBE TO WORN AND THE LUBRICATE WILL NOT BE EFFECTIVE , BUT ITS CHEAPER TO TRY LUBE THAN NEW BELT AND DECK. GO TO gymparts.com part# TM001 or call them @ 1-800-496-7278
Feb 03, 2010 | Precor 9.31 Treadmill
Overheating??
If you are able tho rest it then I suggest this procedure as I have for all Precors: Sounds like the wax lubrication has finally boiled off the belt, the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
Jan 20, 2010 | Precor 9.21 Treadmill
Same problem
I would suggest that you reattach the two wire that their because the unit is pull too much current and that safety feature is to protect both motor and lower board from damage. If you have not been instructed by your local dealer about preventative maintenance Most Precor running are double sided, which means both surfaces are usable and are coated with wax. The easiest way without dismantling your unit is to follow this procedure:
You may purchase this wax product @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Aug 23, 2009 | Precor 9.21 Treadmill
Precor 9.21 Treadmill Logo
1,358 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
