Question about Garden
I have a Ferris Mower IS3100Z I have pressure on the left speed control handle but very little pressure on the right handle and very little on the left handle it will not steer right please help circle
  • 74 Answers
SOURCE: 1997 diesel suburban steering goes left
I doubt it's your 4x4. Most transfer case will start turning the front driveshaft, meaning that BOTH front wheels would try to turn.
Could be a brake pad/caliper locking up on your left wheel. That'll make that wheel turn slower resulting in the veering left.
Could also be a wheel bearing. However usually you'll hear a grinding noise to go along with that. And it'll pull rather consistently in that direction rather than suddenly.
Or, what first comes to mind is that your steering box is loose, or the gear inside the steering box is stripped in one spot. Or your front tie rods could be shifting or possibly ball joints. These would cause a sudden shifting/veering.
All of these things are front end related. And also very dangerous. Take it down to any alignment shop, have them put it on a lift, and diagnose immediately.
Worse case scenerio is that a front end part breaks and sends you out of control and into someone else. Please get it checked. A diesel Suburban could do a lot of damage.
Posted on Feb 10, 2009
  • 298 Answers
SOURCE: handle bar vibration/shaking RVF400
Hi there!
I have the same problem but i finally had it fixed.
Your front rim is warped. Have it aligned. Balancing alone would not do the trick as this would only balance the wheel on its vertical axis. (assuming they were able to balance it properly)
Jack the front end up and turn the wheel.. Have a screwdriver or any thing that can serve as a guide with the rim, turn the wheel and if it touches the screw at some point of the turn , then the wheel is misaligned. A new stock rim would cost too much so have it aligned with a good machine shop.
To give you an idea of what im talking about:
www.webbikeworld.com/Motorcycle-tires/wheels/
There's also a chance that the fork fluids would cause this. Fluid levels should be equal. (less likely)
Hope this helps!
I'd appreciate a feedback!
-levibit-
Motorcycle Mechanic
Specialty on Yamaha Bikes
Posted on Mar 19, 2009
panilling9
  • 284 Answers
SOURCE: my mower will steer left but when i try to steer right just click
sounds like your sector gear and pinion are at fault go to sears.com to parts and enter your mod# you gave. if this is the problem could be labor intensive to repair
Posted on May 25, 2009
  • 3 Answers
SOURCE: Minn Kota power drive trolling motor will not
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • 13 Answers
SOURCE: ferris zero mower;eng.dies when releasing brake or control levers
Check seat SW.
Posted on Sep 29, 2009
Testimonial: "Thanks, I've had problems w/that sw. before,I'am going to run an ohms test on it. That tells me where to start."
Finding a linkage diagram for a american yard pro mdl#hwsp2525b from mower handle to briggs & stratton mdl#12c802-0816-03 engine
1 cable goes to the deadman's handle to a silver spring loaded lever on the mower that the spring is stretched when handle is against upper mower handle. The other cable if equipped goes to carb for speed control.
Jun 07, 2016 | American Yard Products Garden
Mower goes to theleft while moweing & u have to push in more on the left handle to get it back in line,therefore cutting speed down
yes but you should of mentioned the brand/style/type of mower. adjusting the tracking isn't the same for every mower
Sep 11, 2014 | Garden
When I push the handle to travel forward the left track move with little power and the right track seems to have all of its power. If I go in reverse the machine will speed up from low to hi but not going...
You should have one hydraulic pump that supplies pressure to a valve body that controls which motor gets the pressure. Check the valve operation to the left motor to ensure that it is opening correctly. Have the left motor tested as it may be passing oil internally from wear. If it goes backwards with both motors working ok but not forwards then it points to the left forward valve not working properly.
Aug 07, 2013 | Garden
What hydraulic oil do i use in my ferris 1500 mower
Ferris doesn 't standard hyd oil. They fully synthetic 15-50w like Mobil 1
Apr 04, 2012 | Garden
I have a 1 yr. ferris mower 2000z 61'' It dies when apply brake.
IT COULD BE THE SEAT SWICH OR THE BRAKE SWICH
Sep 27, 2009 | Garden
What locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
