Question about La Pavoni Europiccola EPC-8 Espresso Machine
I have an europiccola from the 79s that i got off the internet. I can't get it to heat up. I know the fuse is good, the switch is good (i check both) so is the only think the heating coils? If so where can i buy coils that would fit this. It the old kind with the fuse up in the cavity f he heating coil.
    President:
  • 1,618 Answers
If you check the coil with your ohms meter and get no reading then you might be able to find one from crossroads espresso they are the biggest Pavoni dealer 15413444600.
Posted on May 04, 2010
Dissasembling Pavoni Europiccola
Try looking at this site its really good helped me do various repairs to my La Pavoni Pro
http://www.francescoceccarelli.eu/lapavoni_faidate_eng.htm
all the best P
Apr 12, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Fuse keeps blowing La Pavoni Europiccola 1996
Hi That's a short it's all it could be isn't it. Plug? lead? water or damp in the base? try slipping the black base off you will need a security bit to get it off or at least mine does its a t bit with a hole in the middle I think, have a look for water that might be shorting it out also try it in another socket , you never know.
Best of luck.
Feb 28, 2014 | La Pavoni Coffee Makers & Espresso...
Dryer not heating - I replaced the heating element and it still isn't drying.
  • Rank: Guru
  • Rating: 92%, 36 Votes
Yes there is a thermal fuse and a hi limit switch. The hi limit switch is attached to the heating element casing. You said the heating element checks out If you checked it with an ohm meter and it checked out good. If you checked it visually double check it. The hi limit can be checked with an ohm meter it should show continuity. If you dont have a ohm meter you can jump the wires by connecting them using a paper clip or copper wire. Make sure to tape them with electric tape. The thermal fuse is connected with the Heating element and hi limit by one wire and is located at the bottom back of the dryer and slightly to the right as you face the back of the dryer. It is a small two wire fuse and once it trips you have to replace it you can check it and test it just like the hi limit switch. Be careful and always unplug the dryer before starting any repairs. I hope this help. If you need me to clarify anything just let me know. good luck
Aug 25, 2010 | Whirlpool Dryers
A Kennmore electric dryer, model 697267. Heating element checks out ok. Soninlaw said breakers are ok. Dryer drum turns but no heat? I'm 640 miles away, is there a thermal fuse in the circuit.
Aug 25, 2010 | Dryers
My dryer runs but has no heat. I have replaced the thermal fuse. I have checked the breaker, cleaned out the lint trap and checked the air flow which is good. I do not have a volt meter. Kenmore Electric...
Hello there :
There are severaol things that could cause this to happen
Things to check are :
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
I know that you have checked the thermal fuse so you dont have to worry about this.ok
Hope thatthis is very helpful
Best regards Michael
Dec 23, 2009 | Kenmore Dryers
Heating system failure
Please you check temperature switch. It is OK or not.
2. Check fuse ( if any ) Ok or not.
3. Check Selector switch. it is good or not.
Ngajio
Jun 03, 2009 | Samsung MT1066SS Convection/Microwave Oven
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
The water no longer heats up - the lights are on...
There is a 'magic' fuse button hidden in the base of the unit, concealed by a rubber gromit. Pull out the gromit, press the red button and it should come back on.
Nov 19, 2008 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
104 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
