Carrier 38ydb036 6 flashes on control board. Replaced kick start assist kit. Compressor still will not start.
    Guru:
  • 1,524 Answers
Check power at terminals.
Posted on Apr 30, 2010
Maytag French Door Compressor not starting. Replaced burnt Start Relay and Capacitor. New JazzBoard. Compressor still won't kick on. Is there a Fuse that may have blown when the Relay burnt up ?
take out the terminal and check the power is coming to the compressor terminals and if it does then its overload or control board is faulty too.
Oct 03, 2016 | Maytag Refrigerators
Kenmore frost free freezer model253.24452100 turns on but does not freeze. The compressor kicks over then stops. What might it be?
Is the compressor still receiving 120VAC when it kicks off? Kenmore Freezer Temperature Control Thermostat 216788000
If not, replace the cold control. If yes, install a URCO410 hard start kit and listen to it purr... Relay overload capacitor URCO410
Mar 22, 2016 | Kenmore Freezers
GLRS237ZCB3 stopped cooling, replaced start relay
If there's a buzz then a click it's your overload opening when the compressor doesn't start. Most domestic fridges do not have capacitor assisted start on the compressor, they operate on low back pressure starting. A hard start kit might temporarily solve this . Bottom line your compressor is on the way out.
Mar 05, 2013 | Frigidaire GLRS237ZA Side by Side...
Carrier Furnace LED Good, Blower does not kick on
Likely a variable speed blower. Very common to not get 24 to the blower. Carrier is notorious for bad blowers, double check for 240, don't believe it has a separate module, but that's probably all it is. Likely have to replace entire motor. Good Luck
Mar 20, 2017 | Heating & Cooling
Delfield mini freezer for restaurant is not freezing. Unit has power and cabinet fan runs but comp tries to kick on then you here a click and it immidietly shuts off before it can really ever start. Hi...
Compressor is locked up. You have an outside chance of getting it to come back if you install a hard start capacitor. When a locked compressor tries to start it gets hot really fast and kicks the power off to prevent wires from overheating. You can get a hard start kit from wwgrainger or refrigeration supply company. Many times they won't sell direct to the end user. The hard start kit gives it an extra boost when it tries to start. Most times this won't work. Usually the compressor has to be replaced because it is burned out internally. The hard start kit is less than $20.00, so its worth a shot.
Sep 21, 2010 | Delfield Freezers
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
Compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Apr 23, 2008 | Kenmore 44103 Side by Side Refrigerator
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
