Question about Kirby Ultimate G Bagged Upright Vacuum
Gear shift fell out
The gear shift on my Kirby Ultimate G fell out. I'm talking about the gray and yellow foot switch on the back of the vacuum body where you switch it between neutral and drive (depending on if you're using the hose or the carpet attachment).
How do I re-attach it? When put the shaft back in the hole there doesn't seem to be anything that moves or grips.
I was going to take it apart, but I don't have a full set of allen wrenches, so either I just don't have the right one or Kirby has custom sized screws.
Initially it was in neutral when it first came off, but it seems to have switched itself to drive, so the vacuum is essentially unusable without the carpet attachment.
HELP!
  • 14 Answers
This is an easy fix you do not have to fully remove transmission it does help to lower it down by removing screws. Then try to get the right angle and realign the splines I have fixed mine twice, the second time I put thread locker on it and have not had any problem. Steve
Posted on Jun 06, 2010
    Sergeant:
    Champion:
  • Kirby Expert
  • 357 Answers
Take it to a vacuum store. Don't try fixing this yourself. You will be sorry. Pay a professional for this one. It is fixable, so don't worry. The thing is, it has to be put back at the right angle or the transmission won't work
Posted on May 01, 2010
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Kirby drive gear not working
you will need a new cam bracket, contact your local kirby agent
Feb 15, 2013 | Kirby Ultimate G Bagged Upright Vacuum
The foot pedal to go from drive to nuetral on my G series fell off and i cant seem to get it back in
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it off. Four screws hold the upper motor shell in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and remember to replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Mar 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
The techdrive of my Kirby Vac fell off why and how do I fix it. I am an electrician.
The pedal assembly must be replaced, as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
1935 KIRBY Model R*
19?? KIRBY Model 2R
19?? KIRBY Model 3R
19?? KIRBY Model 4R
19?? KIRBY Model C
1939 KIRBY Model 2C
19?? KIRBY Model 3C
19?? KIRBY Model 4C
Model 505 - 1945
Model 508 - 1948
Model 509 - 1949
Model 510 - 1950
Model 511 - 1951
Model 512 - 1952
Model 513 - 1953
Model 514 - 1954
Model 515 - 1955
Model 516 - 1956
Model 517 - 1957
Model 518 - 1958
Model 519 – 1959
Model 560 - 1960
Model 561 - 1961
Model 562 - 1962
1963/64 Sanitronic VII (Sirocco)
1965-67 Dual Sanitronic 50 (Sirocco)
1967-70 Dual Sanitronic 80 (Avocado green)
1970-73 Classic 1CR (Medium brown, gold bag)
1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
1976-79 Classic III 2CB (Candy-apple red, plaid bag)
1979-81 Tradition (Dark blue; intro of paper bag)
1981-84 Heritage (Gray/orange)
1984-89 Heritage II Legend (Charcoal/gray/red)
1989-90 Legend II (Dark rose-pink)
1990-93 Generation 3 (Alabaster)
1993-96 Generation 4 (Medium gray)
1996-99 Generation 5 (Maroon)
1999-01 Generation 6 (Black/Yellow)
2002-05 Kirby Ultimate G
2005-06 Kirby Ultimate G Diamond
http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby heritage model 1hd. wires fell off safety switch. Need color to position on switch
if your looking at the back of the switch were the wires go in. Starting from left to right. you will see letter below the hole were the wires go in. for example, Y , yellow or " R " for red. this should help.
Nov 19, 2009 | Kirby Heritage II Vacuum
Drive switch fell off. how do you fix this?
Here's a free online guide to help with this problem...
http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL_W0QQugidZ10000000011180003
Please don't forget to rate it if it's helpful. Thanks!!\
Marci
Sep 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Motor Sprocket gear.
hmmmm... not sure what it was doing in the fan chamber but anyways - go HERE and you will see how it is installed (picture next to step #10).
Makes sure you use 2 gears of the same color. If you need a new one you will find it HERE.
Good luck
Rocky
May 26, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
408 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
