Question about Western Digital External USB 2.0 80 GB Hard Drive
The drive started acting up and now can not be recognized by either of two different computers. The white front light just flashes. Is there any hope.
    Genius:
  • 1,112 Answers
Hi:
It might be that the drive has crashed, especially if it does the same on both computers. Harddrives are rather inexpensive these days, you can purchase a larger capacity one and install it in the same case, just open the case and take out the HD, and take it with you to the store, to make sure you get the same interface inside the case as with the HD. Install the new HD in the case and their you go.... New HD and More Storage space....
Posted on Apr 30, 2010
Lexar Echo MX not being recognized
Try this: Go to Start, right click on My Computer, select manage. In the left pane click device manager, scroll to Universal Serial Bus Controllers. Delete all of them. System may not allow some to delete, thats fine just delete all that it will allow. Then leave your usb connected to the PC and reboot. OS will reinstall all usb drivers on its own, and it may then see your stick.
Jun 11, 2014 | Lexar Electronics - Others
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
My laptop can not recognized my 4gb genx usb flash drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Jan 19, 2012 | PNY Electronics - Others
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
How can I make my USB flash drive work again? I asked this question before but I have a Mac, not a PC. no light turns on, nothing comes out in the computer, I have tried it on different computers, i'm...
An USB flash drive is made out of a memory and extremely simple controller chip installed on a tiny board with a connector.
If the drive is completely unresponsive then the chip died. This is terminal, nothing can be done to save it or to recover what was in it.
Aug 11, 2011 | Computers & Internet
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have an external 500 GB HD. I try to plug it in to my laptop and the light on the front just flashes. The laptop doesn't recognize the HD, and there is no sound coming from the external HD
For that make sure usb cable works fine.
Try with different usb cable.
Also connect usb cable in different usb ports of computer.
Right click on my computer then click on proeperty then hardware->device manager.
Then click on sign of usb controllers then uniunstall all usb drivers 1 by 1.
then restart computer.
Then check.
If still not recognized then when you power up the computer press F8 key then enter in safe mode.
then check.
in normal mode again.sometimes harddisk need to start in safe mode .
Let me know if you need more assistance.
thanks.
Nov 05, 2009 | Western Digital My Book Essential Edition...
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computer wont recognize usb drive
try to use another connector! and try connecting it to other USB ports!
Dec 06, 2007 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Usb flash pen drive
i have bought kingston pen drive 8 GB..d problem is that files get corrupted...there r all sorts of different symbols instead of the actual file name...the space occupied by it also changes somehow....i tried formatting it but the problem persists.. i encountered same problem with my earlier SONY 4 GB PEN DRIVE(vaio)... please suggest some remedy..
Jul 12, 2007 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Western Digital External USB 2.0 80 GB Hard Drive Logo
212 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
