Question about Sony KP-57WS500 57" Rear Projection Television
Double picture out of alignment
The picture show double, the remote can not fix ,out of alingment
    Genius:
  • 1,112 Answers
Hi:
Your problem is its time to replace the convergence IC's. Replace both of them as if one has failed depending on which color is out of convergence the other is not far behind. They are the two large black IC's mounted on a large metal heatsink, also while replaceing them check the small yellow or green micro fuses underneath the IC's to make sure none of them have opened from the result of the IC failing.
Posted on Apr 30, 2010
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
Showing double and red
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2010 | Panasonic 52LCX1516 52 in. Television
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
Aug 11, 2009 | Toshiba 55H70 55" Rear Projection...
Double image, fuzzy picture
The problem was caused by poor projector alignment. Alignment was off because we recently moved the TV from a friends house.
This particular set allowed me to realign the projectors with the remote control from a setting in the TV's menu. It was as simple as opening the menu item then aligning the cross-hairs with the remotes cursor. There are 3 projectors, one for each color. One is fixed and the other two are movable. They need to be perfectly aimed in order to get a clear, properly colored image.
When you find yourself with an electronic device and no operators manual it pays to spend the time and effort to download it from the internet.
Problem solved, thanks
C L Ganske.
Apr 11, 2009 | Televison & Video
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Showing doubles (red)
Not the red CRT-----problem is called convergence mis-alignment.
Please provide make,model and age for accurate repair details.
Nov 03, 2007 | Televison & Video
Sony KP-57WS500 57" Rear Projection Television Logo
160 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
