Question about Kenmore 45081 Front Load Washer / Dryer
Washer shuts off and flashes code 06 - Kenmore 45081 Front Load Washer / Dryer
  • Russell Owen Apr 30, 2010
    Yes it is Fo6. I've tried unplugging it for 30 minutes and still am having the problem
  • Rick Ead
    Rick Ead May 11, 2010
    is it f6 should be an f infront of what code its giving ?
  • 1,998 Answers
Ive had this error code before its a drive motor tachometer error it is the same error code in both kenmore and whirlpool when you order to replace the piece it comes in as enitre harness fromthe motor all the way up the side of the machine to the board
Posted on Apr 30, 2010
Washer front loader wont spin or unlock
Find your book that came with the washer, and it will have trouble codes. Your lights are probably flashing a code. Count the flashes then look up your code in the book. That is a good place to start.
Mar 06, 2014 | Samsung WF203ANW Front Load Washer
Kenmore elite he3 model 110 f-06 code comes on and washer stops .
I was getting a F-xx code can not remember the number.
If you remove the bottom front plate , I remember 3 three screws.Behind that is the filter for the machine, mine had a 2-3" white cap that came off with a screen inside that was plugged. When you open it up you can get a fair amount of water come out. The machine will not work until you put the front cover back on.
UNPLUG the machine FIRTS
Aug 23, 2012 | Kenmore Washing Machines
Washer beeped a few times then stopped and is flashing F then 06 i don't know if the 06 is time remaining or part of the code
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F is flashing and 06
Press PAUSE/CANCEL once to clear code. Press START
Aug 12, 2009 | Kenmore Washing Machines
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the MCU
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WASHER STOPS WORKING AND FLASHES 06 F
F06
Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
Replace failed component.
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
  • Check the MCU
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
81 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
