Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony DLP has Dark Screen
When watching a movie during a dark scene or night scene I can barley see the picture? I replaced the DLP bulb a year ago and do not have the replace bulb alert on the TV. Any Ideas?
  • Anonymous Mar 22, 2014
    have replaced bulb still too dark ... any ideas? thanks
  • 4,234 Answers
Techman007 is correct here. Lamps have "lifetimes" of a certain number of hours. The lamp indicator is there to let you know that the lamp is likely to fail soon as it has reached its expected lifetime. That does not mean that there aren't lamps that will fail sooner. In your case, the lamp is not producing the amount of light required for a good picture. This is normal for lamps as they age. The light output for all lamps decreases with use. Normally this does not occur in such drastic ways however.
Since you are getting light from the lamp, the ballast is working as expected. The ballast is similar in function to the ballast for a flourescent light, it either works or doesn't.
One other thing that can be checked is the fan area and any glass surfaces for dust and dirt. Again this will effect hte overall light output, but not in such a drastic way. When you next change the lamp, carefully clen any glass surfaces as well as the fan area. Please note that any access to the lamp area should be done after the lamp has had time to cool. These lamps are burn hazards.
Dan
Posted on Apr 30, 2010
    Genius:
  • 1,112 Answers
HI:
Just to let you know if the replacement bulb was not a philips brand lamp then it may be time for a new one. Usually when DLP's start showing dark or not enough light then its time for a new lamp. The lamp alert does not have to come on in order for the lamp to be worn depending on the use of the set of course. The lamps are on a timer circuit that keeps the hours of use of the lamp even tho its only been a year does not mean the lamp is not worn. If the lamp you brought was a generic type lamp like, LTI then its time for a new one. Make sure you buy a Sony brand lamp as they all use Philips 120watt bulbs.
  • Sony Master
  • 3,866 Answers
The idea I have for you is the bulb connector and or ballast. what has happen is the ballast/connector is not providing enought power to the bulb and when these sceans come up well you just cannot see verry good.
The worse it can be is the light engine in this unit witch is $850 to replace.. But I would check the ballast first.
thanks and be considerate and leave a rating and feedback for your free answer today.
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Samsung DLP Dark Picture
try to reset the tv setting to its manufacturer settings and see if it fix the problem
Feb 01, 2009 | Samsung DLP HL-P5663W 56" TV
Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Dlp has dark blue areas on screen
Have you tried magic focus? if that doesn't work
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Jan 22, 2008 | Samsung HCN4226W 42" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
764 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
