Question about Dryers
Dryer cord access
I just got a used Kelvinator clothes dryer from a friend. It has a 3-prong cord which I have already removed with no problem. However I can't seem to get the access I need to get the 4-prong cord hooked up. Unless I can somehow take the back panel of the dryer off to get my hands behind the wiring to apply the screws and nuts correctly, I don't see how I can complete this task. I know where to connect the wires, just can't physically find a way to do it. Please help!!!
    President:
  • Dryers Master
  • 2,651 Answers
Not sure why you wouldbe able to remove the one cord and having an issue connecting the other.
perhaps the old cord had like a y(open end) connectoin point and the new cord has eyelets(closed end)??? if thats the case and the y connectoin was behind hte terminal block( or sandwiched between) by removing the terminal block screw you can mount hte new infront of block, secured by main screw.
Posted on Mar 25, 2008
How to connect power cord
Hello Jake. It depends on whether or not you have a 3 prong cord (3 wires), or a 4 prong cord (4 wires). So I'll just tell you both.
For Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case
wrightly_3.jpgHere is an example of a 3 prong cord for a whirlpool dryer. If your terminal block has 5 screws, you still do it the same way as stated above. these wires are not colored. You should have a strap in the middle that is connected with the middle wire. Sometimes there is a wire attached there instead of a strap.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Here's an picture to use as an example;
wrightly_4.jpgJust be sure to use the strain relief at the opening where the power cord first enters the dryer. It will help secure these connections against being pulled loose or cut on the cabinet, and that could pose a risk of you coming close friends with 240 volts. Not a friend I want to have.
I hope this is helpful,
If you have any questions, feel free to ask.
thanks for using fixya
Mike W.
Aug 12, 2011 | Whirlpool Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
I need help hooking up my Maytag Dryer
here's a link you can try that explains both the 3 and 4 prong dryer cord configurations.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If this is an older home that already has a 3-prong receptacle installed, you can still use a 3-prong cord. However, if this a newer home, or if you plan on relocating the appliance, or making any repairs to the existing receptacle, you need to use the 4-prong. I hope this helps you.
If you weren't talking about the dryer cord configuration and need assistance with something else, please let me know.
Jan 09, 2009 | Dryers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Regards,
Rick
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Burning smell
Hello benson131,
Based on your description, you already identified the problem as being a bad power cord. There is a high probability that the place where that cord is wired into the back of your dryer that the terminals worked themselves loose. Loose terminals become resistive and do not allow adequate current flow to maintain dryer temp so more current is required and that additional current will cause the insulation to melt on your power cord. I suggest you do the following. First off, unplug that cord from the wall recpetacle. Determine if you have a 3 prong or 4 prong plug. Go to a local home goods store like Home Depot or Lowes to get a replacement cord set that matches the one you have.. ( probably cost between $10 - $15 ) Once you have the right cord.. pull the dryer out and away from the wall.. Locate the feedthru on the back of the dryer rear panel.. ( that is where the cord goes into the dryer) and usually has some kind of cable clamp to keep the cord from being yanked out of the dryer.
Loosen the cable clamp and then look for an access panel where the wires physically get tied into the dryer. Once you have the cover removed, you should see a terminal block with 3 or 4 positions and color coded ( red/ white/ black and or green.. ) the Green is a ground wire and may be secured to a frame stud and not on the terminal block. Unscrew the wires from the old cord and reinstall the new cord in its place. Make sure you match the colors correctly ( red to red, white to white,black to black and green to green if it has a green position of green to a frame screw.) Make sure these wire terminations are reasonably tight. Once together, put the cover back over the terminal block and make sure the cable clamp is snug. Then plug it in and run it.. Your problem should be resolved.
Let me know if you have any questions with this...
Regards,
Rick
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
