Question about Panasonic Viera TH-42PX80U Plasma TV
I try to turn on TV but a red light just blinks.
The red light is by the start button. I can unplug then plug in the TV and sometimes
it will turn on but usually the red light just blinks.
  • Panasonic Master
  • 8,457 Answers
Ur power supply board is dead,have problems with componnents call capacitors,they have bulges,puff up it top and leakage it gases.That why u getting iregular power to ur tv set.U know basic electronic's,and soldering?Take ur tv aparts,search all around ur power supply board,to replaced these bulges,and puff up capacitors.Ur tv power will return to normal operation.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 30, 2010
2 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Sep 05, 2012 | Sharp Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Aug 23, 2007 | LG 32LX1D 32 in. LCD Television
Tv will not turn on
The blinking red light is telling you that the set did not start up due to an overvoltage somewhere in the set. Most likely the main power supply has a fault like a bad regulator IC or a component associated with it, or there is a fault in the sweep power supply somewhere. if you have no electronic repair experience, play it safe and call out a tech to assist you with this repair. Good Luck.
Mar 19, 2007 | Toshiba 43H71 43" Rear Projection...
Panasonic Viera TH-42PX80U Plasma TV Logo
282 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
