posted by wes11 on Mar 25, 2008
I can't figure how to get the hard disk our of the case of this computer. I have opened up both sides of the case and the hard disk is in the cage with the CD players and floppy etc. The hard disk has a screw or screws on the far side that hold it in the cage and there is no hole on that side for remove the screws. I assume that the whole cage comes out, but don;t know how to get it lose. I tried removing the front, but it seemed like I was going to break it if is has a screw somewhere holding it. I just want to change out the hard disk. Hope this is clearer.
wes11
Comment by wes11, posted on Mar 25, 2008
Melnavz answered, but I had stated the problem so poorly before that there was not enough information given for an answer. Hope this works. I found a HP Medalion manual but if didn't have any info on how to remove the hard disk from the case.
wes11
wes11
Solution #1
posted on Jun 13, 2008
The side panel of the case should be removable to gain access to the screws. I have also seen versions that the card cage itself is on a hinge, and swings out of the case (with the removal of a few screws) that then gives access to the drive screws.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP (298012-001)
HP (5065-2501) Mini ATX Desktop Slimline Case
Acer (91.96320.DOS) FlexATX Desktop Case
Antec (761345-12284-9) Mid-Tower Case
Antec (4U26ATX450) ATX Rack-Mountable Case
Antec (3U25ATX550) Extended ATX Rack-Mountable Case
Antec (1U26ATX250) ATX Rack-Mountable Case
Can you Help with these PC Cases problems?
Apple G5 Case with Power Supply (p/n...
Apple g4 digital audio Power...
Dead supply. Where can I get... Answer This...
Repair Service
Find PC Case Repairman Near You:
