VERY POOR WATER PRESSURE/ THE WATER JUST TRICKLES
VERY POOR WATER PRESSURE/ THE WATER JUST TRICKLES INTO BASIN OF MY KENMORE WASHER TOP LOAD
    President:
  • 957 Answers
Shut the water off to the washer and remove the filler hose at the washer. There should be a screen there to catch debris. Inspect the screen, it may be clogged. While you have the hose off get a 5gal. pail and see if the water flows freely into it. If the screen doesn't exist and the water flows freely from the hose then you may have a clogged or defective valve.
Posted on Apr 30, 2010
    Sergeant:
  • 166 Answers
The first thing I would check is the hoses where they connect from your pipes to the machine. Cut the water OFF and unhook the hoses. There should be screens to block trash in the hoses and on the inlet of the washing machine. Clean these screens if dirty, reassemble, turn on water, and see if pressure improves. If not, can possibly be inlet valve has trash in it and may need replaced.
Just had my Kenmore delivered yesterday and the water trickles in! Initially, when I moved it to warm it did come out normally, but then it also slowed to a trickle. Same if I move it to rinse. I called...
There is a wire screen filter in the water hose where it connects to the water supply. It's probably clogged with sediment from the water supply. It usually happens with the cold water only so try hot water and see if it's better.
Feb 05, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
No water pressure on fill.
Hi, If you have checked the screens in the mixer valve and there is nothing plugging it, then it is most likely the mixer valve.
I hope this helps. Please let me know and feel free to rate my response to you.
Thanks
Vic
May 20, 2009 | Kenmore 22422 Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
I have a kenmore model # 110.26934691 / 90 series
Check the warm and hot cycles. If they work then the pressure valve needs replaced. Disconnect the watert hose to machine and make sure water comes out. Back screens may be clogged also.
Jan 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
