Question about Ricoh Aficio 1018D Copier
Ricoh Aficio 1018 printing lines, seems to be photoconductor
I have a Ricoh Aficio 1018 and need to do some service to it. The problem I am having is that it is printing black lines on the paper. Due to the pattern, it looks like the culprit is the Photoconductor. I took it out and saw that the photoconductor was indeed dirty. I need detailed instruction on cleaning it.
  • 1,110 Answers
Cleaning the drum will not help. Depending on many factors including drum condition, number of pages printed etc, you will need at least to replace the drum cleaning blade. This is a common cause of black streaks. The drum should have been clean. The fact that it has toner on the surface is pretty good proof that the cleaning blade is bad. The part number for the blade is B0392289. I would do a search for this part and get one before you even think about trying to deal with the streaking problem. Once you get the blade, if you are mechanically inclined then replacing the blade is not difficult.
Good Luck and Thank You for using Fixya.
Posted on Apr 30, 2010
  • haocai88 Sep 11, 2010
    one black line with new cleaning blade after 10000 pages. cleaned charge roller, then the black line come back(from grey to dark). is it a bad cleaning blade or something else?
Ricoh mp c3000 colored copies are double print
Could be drum units there are 4 drums or fuser assy. since you said color only I said drum unit try scanning a single color see which one does it . Will need to call a copier company or go online and buy a whole photoconductor . You will need to know how to initialize unit before you put it in.
Jan 14, 2014 | Ricoh Aficio 1018 Printer
We have Ricoh Aficio 1018 , machine functions , gives print without the matter printed
Sounds like a bad photoconductor unit (PCU), or problem with the transfer roller which is mouned inside the right side door. The PCU consists of 2 main sections; the development unit, with developer ang mag roll (on the bottom) and drum, with charge roller and cleaning blade (on the top). If the gears that turn the mag roll go bad, toner will not be applied to the charged drum. If the transfer roller is missing or not being charged the image will not be transferred to the paper. Check the connector from the copier to the right side door and the leaf springs that carry the charge from that wire and contact the transfer roller.
Sep 07, 2012 | Ricoh Aficio 1018 Printer
Sc 500 como resolver
That means main motor malfunction, but i am positive that you have to change at least LOWER DEVELOPMENT UNIT plus 2 gears (...3060 and ...3062). The problem is that your PCU (photoconductor unit) is blocked. Please call service for help
pifonski
Apr 19, 2011 | Ricoh Aficio 1018 Printer
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
Lines and marks appear on printed pages
it could be the photoconductor belt which is worn out. its no use replacing photoconductor belt as its around $1000. my advise will be to change the whole printer. SPC210SF is not a good printer. it has alot of problems and its very noisy. I work in Ricoh.
Jan 04, 2011 | Ricoh Aficio SP-C210SF Printer
Tenho uma ricoh 171 esta dando erro sc500
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
Dec 23, 2010 | Ricoh Aficio 1018 Printer
Seems to print a red or yellow line down the edge about 1 to 2mm wide, prints black fine. All toners over half full. Test page seems fine but can see red line along edge.
What ever color the line is you need to replace that photoconductor unit. They can be ordered from a Ricoh dealer and come with instructions for installing.
May 04, 2008 | Ricoh Aficio 3800CMF Laser Printer
Printing rubbish
What computer? What Operating System? What type of connection to the 1018? What driver type?
Mar 24, 2008 | Ricoh Aficio 1018 Printer
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
424 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
