Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer is offline when turned on, therefore won't print. Computer notes that the printer is offline etc therefore print jobs just spool to the printer. How can I force to be online?
  • fgibb May 03, 2010
    im having the same problem except my laptop i was using is broken and the new laptop can't recognise the printer at all because it's still offline...
  • 560 Answers
Male sure that the printer USB cable is properly connected to the computer. Right-click on the printer icon and select "set printer online".
Posted on Apr 30, 2010
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
Won't print - d5160 photosmart. system subspooler app error
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
My printers status is offline, therefore I can not print.
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 20, 2011 | HP Photosmart C5180 All-In-One InkJet...
Cannon printer mx860 says offline cannt print from computer how do I fix
Also on the computer:
Jan 22, 2011 | Office Equipment & Supplies
WHEN WE GO TO PRINT, IT SAYS PRINTER OFFLINE.
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online.
or
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 03, 2011 | Office Equipment & Supplies
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE:
This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
My printer has a backlog to be printed.I want to erase the backlog and start fresh.When I turn on the printer it starts to print the stuff I don't need anymore.How do I do this?
Pause the printer by taking it offline.
At the bottom right of the screen, you should see a printer icon. Double click on that icon to open the print queue.
Once the queue is open, highlight the print jobs that you want to clear and then delete them.
Don
Nov 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
MFC6490 PRINTER goes offline. It does not print
go to control panel>> adminstrative tools>> services
select the printer spool and right click. stop the spool. go back to the printer properties and delete the print job. restart the print spool.
May 29, 2009 | Brother MFC 6490CW InkJet Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
942 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
