Question about Husqvarna Garden
Husgvarna lth 155 ride-on blades not engaging
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
  • 4 Answers
SOURCE: dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
Posted on May 18, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 133 Answers
SOURCE: Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Posted on Aug 13, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
How do I fix the steering on My Husquvarna Model LTH 130 riding lawn mower?
Go to bing.com search husqvarna Lth 130 and you should come up with a 50 page manual on the mower that might help with problem.
Oct 28, 2017 | Garden
My deck isn't engaging and I'm sure I screwed up the electrical. I disconnected the pto and it's not engaging now
do you think you dammged the cable or connector to pto clutch as it's electrical ?? if so you'll need to repair/replace this
May 18, 2014 | Garden
Need a belt diagram for my 2000 LTH 130 Lawn tractor
Look in your manual. If need one, go Goggle husqvarna lth 130 manual.
Sep 08, 2012 | Husqvarna Garden
Everytime I engage blades and start to cut white smoke blows out front of engine. Is mototr blown? cheaper to fix or replace?
The muffler discharges out the front as you would see it from the seat. The white smoke in the exhaust when loaded indicateds that you may be having trouble with oil and vacuum inside the engine. At best requires partial disassembly. This may get expensive. I recommend careful consideration regarding the decision to try to repair or to choose to replace.
I hope this helps.
Jul 27, 2011 | Yard Machines 155 Torque Briggs Stratton...
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Yard Machines RL 638, '07 model, will not start
Sounds like the blades may be engaged. The cable may not have disengaged completely the last time. When the engine is trying to turn over, the belt is engaged trying to turn the blades which could be why the deck is jerking. It will not start if the blades are engaged because of the safety switches.
Apr 30, 2010 | Yard Machines 155 Torque Briggs Stratton...
What ingages blades ,blades not engage
On most riding mowers flipping the handle to engage the blade causes an idler pulley to engage the drive belt, which takes up the slack in the belt and pulls it against the drive pulleys. A few odd-balls have an electric clutch to engage the blades.
Jul 10, 2009 | Garden
Garden Logo
60 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
