Question about VuPoint DV-DV1-VP Camcorder
TV recording problem.
I connected the TV and the camera using the AV cable, but then on the camera the screen is black. The time indicators and others are still there but the cinema on the TV doesn't show up. Why?
  • 8,596 Answers
The LCD monitor does not work when the
camera is connected to a television. -p.41 of user's manual
Posted on May 16, 2008
Xbox360 Recording Problem (With DVD Recorder)
FixYa, stop asking me to fix Xbox 360 problems, I DON'T OWN ONE NEVER HAVE. Also I don't care about other people's problems, just mine.
Apr 06, 2014 | Microsoft Xbox 360 Console
No audio
You have to have the cable with three colors, yellow is video, white is one side stereo and red is other side. Plug into av on back of tv then select the av
Dec 25, 2013 | Philips Blu-ray Disc Player with Wi-Fi -...
Trying to use the vcr to record a serveillance camera not sure what cables I need to do this
By the look of the VCR it should be simple to connect the camera to it, using the front socket. As long as the camera has a RCA video out socket. You then just get a standard RCA cable and the yellow coded plug goes into the video out on the camera and video in on the VCR. Both should be coded yellow. If you need the sound then the other two Red (right) White (left) are audio. If the camera is mono put it in the right socket. Your not very clear on the cause of the record failure, but if there is no picture set the channel selector (when setting the record) to the AV socket that the camera is connected. Also check that the PDF control is set to OFF.
Dec 14, 2011 | Curtis CMV41001 VCR
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
What is meant by av out which at the side of camera digimax L60
AV out is an analog video output suitable for sending a signal to a TV or video recorder that has the appropriate inputs. You should have been sopplied a cable with the camera to make this connection. Typically this would have a mini-jack on the camera end and up to three RCA "phono" style plugs on the other. You can use this to view your pictures on a TV screen.
Nov 08, 2010 | Cameras
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
LCD Scree went blank/black
No problem. Discovered that fix by accident when my camera did the same thing. Since the screen was blank, tried arranging camera setting using the camera's AV cable with the TV, and discovered that fixed it. Apparently corrosion builds up on the AV cable plug switch (which also turns the screen off when inserted), and inserting/removing the plug several times can fix it.
Jul 10, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VuPoint DV-DV1-VP Camcorder Logo
49 people viewed this question
Top VuPoint Video Cameras Experts
Are you a VuPoint Video Camera Expert? Answer questions, earn points and help others
