Question about Kenmore 73952 Gas Dryer
Dryer not heating up
I have a Kenore 400 series home dryer 9gas) . I put a load of wash in to dry. Ran the dryer for 30 minutes to find that their is not heat in the dryer and clothes are still wet.
    President:
  • 1,619 Answers
Ignitor may not be working, or gas valve is not opening.
Posted on Apr 30, 2010
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
It takes 50 min to dry a load of clothes in my 400 series electric dryer can you tell me the problem. I checked the exhaust it looks clear thanks.
It could be heating problem and best way is to check for continuity in heating element and sensors and thermostats and limiters and thermistors in the dryer
Nov 17, 2010 | Kenmore 400 6943 Dryer
Still more of the same
The exhaust is clogged or restricted holding too much heat in the exhaust housing or the limit t-stat has gone bad. This is the t-stat sitting next to the thermal fuse. Good luck.
Feb 11, 2010 | Kenmore 400 6942 Dryer
My Kenmore 400 series is taking too long to dry
Make sure the vent and tube are clear and not blocked in any way, if clear try washing off the lint screen with hot water, softener will clog the filter
and not allow proper air flow, water will bead up on screen if this is true
Oct 27, 2009 | Kenmore Dryers
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Kenmore 73952 Gas Dryer Logo
143 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
