Question about Canon PIXMA MP150 All-In-One InkJet Printer
The waste ink asborer is full
The printer won't work, the note reads the waste Ink asborer needs replacing
    President:
  • Canon Master
  • 2,022 Answers
First you try with reseting if it is not works then you need to replce just follow this,
Just follow these steps to fix this,
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Apr 30, 2010
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Printer won't work, note reads thInk well asborer needs replacing
The waste ink absorbers are a couple of pads at the bottom of the printer. Contact Canon (or a service center) if you want to buy a replacement (not all manufacturers sell them). It can be hard to reach the pads but give it a shot. If you are reusing the pads, rinse them with running water until it runs clean. Then once they are dry, reinstall them and put the printer back together.
Then you need to reset the printer waste ink counter:
With the printer connected to power but not on, press the Power button while holding the Stop/Reset button. When the power light is lit, continue to hold the Power button and press the Stop/Reset twice. Release both button (in any order). The printer will now enter the service mode.
When the green LEDs are lit, press the Stop/Reset button 4 times to get to the Waste ink counter reset. Reset this value. Then press the power button (saves the setting) and then restart the printer.
I hope this helps.
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Epson r 2400 top trashcan light and ink light flashing
For Jane106:
The ink-out and paper lights flashing alternately indicates the "service required" or basically ... "change my ruddy diaper, it's full of ink".
This is not as bad as it sounds and you have a few options:
1. Take it to a service center and have it serviced (ie: have the waste pads replaced)... It's expensive though so be warned.
2. Download the SSC utility (Google: SSC epson reset) and use this to reset the protection counter in the printer memory.
Note: READ the manual, it's not overly intuitive.
If you've gone with 2. you'll still need to do something about your waste ink and the simplest is really to modify your printer to redirect waste ink from the cleaning pump to an external tank.
Again Google is your friend so keywords like "Epson waste ink R2400" will find what you need. Some kits are better than others but then I'm biased :)
Hope that helps.
Jan 15, 2009 | Epson Stylus Photo R2400 InkJet Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
