Question about Delta Faucet 2530CBLHP/H25 Innovations 4'' Centerset Bathroom Faucet - Chro
There doesn't seem to be a set screw in the small hole where it is suppose to be. Is it recessed in to the hole? Thanks
  • 349 Answers
If you have a hole for it it probally is recessed to tighten it to handle
Posted on May 05, 2010
How do I remove housing to get to the ignition switch on a 2007 Pontaic Torrent
Isn't it a steering column cover? These are usually or almost always held with screws that are recessed in deep holes in the cover. Look from underneath at the steering column. See the holes in the cover? Try a phillips head screwdriver to begin with. Sometimes the screws are torx head screws, sometimes just regular hex head screws that need a small socket over them. If there are no screws, then the cover will just pop off.
Nov 19, 2016 | 2007 Pontiac Torrent
I want to remove the lever handle off a set of caroma elegance leverbasin taps p/t 631140c5a
Look around the base of these to locate 2 small holes(1 in each). Recessed in these will be a hex/allen head screw that nees to be loosened to remove
Aug 27, 2014 | Home
How to remove the key switch from a 1994 suburban
Under the steering wheel you will see some deep recessed holes, and those will have hex style screws in them which hold the top and bottom halves of the plastic cover together around the steering column. Once you remove those three or four screws, you can take off the cover and get to the ignition switch. if you look closely at the area right around the ignition switch you will see a small hole or recessed spot where you can take a screw driver and depress a small pin and it will let the whole ignition cylinder to slide right out.
Jul 16, 2014 | 1994 Chevrolet Suburban
Screw size for mount and tv un32f5500af
This TV is VESA mount compliant with a spacing of 200MM x 200MM. the mount holes are M8 1.25 and about 23MM deep. 3 of the holes are recessed and one hole is near surface. Adding a 2-3 MM margin for a typical washer and the mount itself, M8 1.25, 25MM screws might be the best to mount this TV.
I am using the Sanus simplicity SMF3 mount (bought from costco). The spacers provided with this mount are 22MM which makes the supplied M8 35MM screws too small with the spacers. Without the spacers, the supplied M8 16MM screws are too small. With spacers, I think the screw size should be M8 45MM and without spacers it should be M8 25MM
I am thinking a vinyl washer might be a good addition to the assembly (with my sanus mount).
Found this site useful to understand the screw dimensions.
http://www.fastenermart.com/html/metricsizes.html
Dec 22, 2013 | Samsung Televison & Video
How do you remove the part of the manual thermostat that shows the mercury bulb? I want to install a programmable one.
Hello my name is Heath it will be my pleasure to assist you. There are very small screw recessed into small holes you will need a small screw driver there is three small screws that you will have to loosen to get the thermostat off.
Sep 15, 2011 | Heating & Cooling
250 Polaris Trailblazer wont start- new spark new filiter help
Did u choke it ? -stroke are very cold blooded Mine(2003) needs a choke after sitting 1/2 hr at 70 degrees.
Mar 31, 2010 | Polaris ATV
Seem to be a screw in the case under keyboard how
with the laptop over on its back you will see two screw holes seperated apart by a couple inches right in the middle of the case. These screw holes are in the middle of two recesses molded into the case bottom. The screw on the right is the screw that releases the keyboard. Once this screw is removed, the only other thing holding the laptop keyboard is the 5 retaining tabs along the bottom of the keyboard. Release these and rotate the keyboard up and release the cable from the motherboard.
Jan 18, 2010 | Sony VAIO VGN-N320E Notebook
2008 cobalt s/s Turbo rear view mirror
There should be a set screw which is usually a small recessed hex head. a set of small allen wrenches will do the trick. It may also be a torx style screw. Just look carefully and you can fix this easily.
Sep 29, 2008 | 2006 Chevrolet Cobalt
Tip of dvd imput cable broke off recessed in tv
The center of the tip should have some open space to carefully screw in a small screw (by hand) and pull out.
Mar 15, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Delta Faucet 2530CBLHP/H25 Innovations 4'' Centerset Bathroom Faucet - Chro Logo
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
