Question about Microwave Ovens
LG MICROWAVE LMVM2055ST
My problem is the key pad some times it does not work like stop/clear, #4,#3 and other buttoms. It would like try to open the control and see if any dirty or moist inside, please let me know how i can open it and see and the worse i will replace for a new piece? thank you for you help
  • farfara Mar 02, 2009
    I had the same problem I ordered a complete new door from LG and 6 months later I have the same problem. The question is how to disassemble the door.
  • 185 Answers
Your gonna have to get another key pad
Posted on Mar 25, 2008
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
We have a over-the-range LG Microwave Model #LMVM2055ST purchased in 2006. It was working fine until today when I tried to heat something, it wouldn't start. The light works inside when you open the...
Most likely the touch panel is bad. You can try ordering a new one from repairclinic.com by searching with your model number. If you find that replacing it doesn't help, return the panel within 30 days and you are only out the shipping costs. With what you describe, it should be the panel itself. Let me know what you find out.
Benjamin
Nov 04, 2010 | LG Over-the-Range Microwave
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
May 26, 2009 | Sharp R-510HW Microwave Oven
Start buttom doesn't work
Okay, it does sound like your membrane keypad is worn out at the Start pad.
It may be available separately as a key sheet or already attached to a new plastic frame.
In case it comes as a key sheet and if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
LG's Latin American Wen sites are here.
Dec 16, 2008 | LG LRM1250 Microwave Oven
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Microwave Ovens Logo
224 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
