Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Not very cold - GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezernot very cold - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 30, 2010
Toyota rav4 diesel starting problems from cold it take a long time to start up when i leve it over night..
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
