Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer won't work, note reads thInk well asborer needs replacing
Printer won't work, note reads Ink well asborer needs replacing
  • Canon Master
  • 5,471 Answers
The waste ink absorbers are a couple of pads at the bottom of the printer. Contact Canon (or a service center) if you want to buy a replacement (not all manufacturers sell them). It can be hard to reach the pads but give it a shot. If you are reusing the pads, rinse them with running water until it runs clean. Then once they are dry, reinstall them and put the printer back together.
Then you need to reset the printer waste ink counter:
With the printer connected to power but not on, press the Power button while holding the Stop/Reset button. When the power light is lit, continue to hold the Power button and press the Stop/Reset twice. Release both button (in any order). The printer will now enter the service mode.
When the green LEDs are lit, press the Stop/Reset button 4 times to get to the Waste ink counter reset. Reset this value. Then press the power button (saves the setting) and then restart the printer.
I hope this helps.
Posted on Apr 30, 2010
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
Hi, I have the Canon Pixma MX310 and I tried to replace the ink cartridge but I messed i up and I still don't know how to replace it... I think it's error 5100 or something because it says it on...
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Sep 24, 2011 | Canon PIXMA MX310 All-In-One Printer
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a photosmart C4700 and it won't print in black How can I tell if it's out of ink?
Follow these steps to check the ink levels: >Click Start . >Click Printers and Faxes . >Right-click the icon for your printer , and then click Printing Preferences . >Click the Features tab. >Click the Printer Services button. The Toolbox window opens. >Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
NOTE:Depending on the printer, the estimated ink level indicators can vary in appearance.
>If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
Aug 13, 2011 | HP Office Equipment & Supplies
My printer is reading error E5... what does this mean?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 15, 2011 | Canon PIXMA MP210 InkJet Printer
The waste ink asborer is full
first you try with reseting if it is not works then you need to replce just follow this,
Just follow these steps to fix this,
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I just spent $46 on ink. printed 14 pics and already ink is reading low on all colors
sounds like you have a hpp printer......continue to use the ink until it wont print...odds are you purchased a defective cartridge....on a side note buy a kodak printer.....the ink is under $20 to replace...and kodak will back their printers more so than most other companies....
Sep 27, 2009 | Office Equipment & Supplies
Replaced ink and wrong catridge message comes up
What I would do is check your maunal to see what cartridge you need for your printer and purchase this cartridge. If you have not need color cartridges before than you wont need them now. Just make sure you inserted the right ink cartridge for your printer
Sep 24, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Ip1300
ReSet it counter numbers,
PressNhold Reset - Press Start
Hold Start - double click Reset
Release both
Press Reset 4 times turn off machine,
It is described in Canon Manual available at 2Manuals.com. ($8.99) also shows the actual ink asborer mats get a set of absorbers part number QY5-0145-000 - remove the machine side
then top cover , 4 screws, better heve rubber gloves
bat(^m^)ike
Nov 25, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
