Question about Canon MP830 All-In-One Printer
MP830 printer will not send or receive faxes. Making a clicking noise inside printer. No error number. Can you help? Regards, Deidre Slade
  • 4,041 Answers
Hello there It worth a try, it could free what stoping it.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
May 23, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a Canon MP830 & I can't print or send a fax Error message 300 - I can't turn off the printer - & it says I have 10% in memory. it is also making a clicking noise
Error No. 300 :
Cause 1: The machine is not ready.
Action : Ensure that the lamp on the Operation Panel lights.
If the lamp on the Operation Panel is off, turn the machine on.
While [COPY] is flashing, the machine is initializing. Wait until [COPY] stops flashing and stays lit.
When the Alarm Lamp lights orange, an error may occur in the machine.
Cause 2 : Machine is not proper connected.
Action : Ensure that the printer cable is securely connected to the computer/
* If using a switching hub or other devices, disconnect the machine and reconnect it directly to the computer and try printing again. If successful, the problem may have been with the device.
* There could also be a problem with the cable(s). Replace the cable and try printing again.
Cause 3 : The name of the machine being used is not selected in the [Printer] pull down menu of the [Print]dialog box.
Action : Select [MP830] from the [Printer] pop-up menu in the [Print] dialog box of the printer driver.
If the [MP830] is not displayed in the printer list, follow the procedure below to confirm the settings.
1) Select [ Print abd Fax Preferences] from the [Printer] pop-up menu.
2) Check that [MP830] is displayed in the screen that is displayed and select the [InMenu] checkbox.
3) If [MP830] is not displyed, click [+] to add a printer.
If [MP830] is not displayed, install the MP Drivers again referring to the Easy Setup Instructions for the operations.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CANT SEND FAX THRU MY CANON MP830
you need to setup and set data for send and receive to be the same to use the same port!!!
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Mp830 printer
Make sure you use an anolog phone outlet.
Then in setup and the area code and phone number.
Place paper in tray, push fax , then dail number to fax to. The machine has to set to receive a fax .
Oct 23, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Faxing
Make sure that you have settings to RECIEVE FAX.
Go to start on your Desktop. Click on All Programs. When window opens, click on accessories. When accessories window opens, click on COMMUNICATIONS. When the Communications window opens, click on Fax. When the Fax window opens, click on FAX CONSOLE. When the FAX CONSOLE window opens, click on RECEIVE FAX NOW.
You might have to wait until your telephone/fax machine, rings and then click RECEIVE FAX NOW if it does not work automatically.
The person who is sending you a Fax might have to inform you they are sending a Fax to you right now.
Hope this is helpful to you. Good luck.
Sep 30, 2007 | Lexmark X75 All-In-One InkJet Printer
Its clicking
Check and make sure that if you have something plugged into the fax/phone ports that it is installed correctly.  I had this noise when I accidentally put the usb cable into one of the ports.
Sep 15, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
41 people viewed this question
old marine
old marine
