Question about Keurig B70 Coffee Maker
Takes a long time to start brewing . how do you clean it
  • Keurig Master
  • 43,501 Answers
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Posted on Apr 30, 2010
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
How can I fix my coffee maker when the water resovior will not drain?
Try cleaning it by brewing a 50/50 mixture of white vinegar and water. You may have to run it through a couple of cycles with a fresh mixture each time. Then rinse by brewing water only a couple of times. Over time calcium and lime builds up inside the tubes of the machine and restricts the flow so this should be done once every few months or as needed. The vinegar will loosen the mineral deposits and flush them out.
Jun 01, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Doesn't complete a full brew cycle before alarm sounds to indicate end of brew cycle. Have to re-start up to 4 times to get a full pot of coffee.... what can be done to solve this issue?
sorry I don't have a solution but actually have the same problem. This is driving me crazy! (not really) I have tried taking the filter out and cleaning the unit with vinegar. nothing helps.
Aug 22, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Jura impressa f9 malfunction 8 i need help whats that
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Jul 08, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group: http://cerinicoffee.com/Saeco_brew_group_Magic_royal_916006715.asp
Cleaning instructions: http://cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Keurig B70 Coffee Maker Logo
117 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
