Question about Danby 10 cu. ft. / 283 liter Chest Freezer DCF1019W
Does not keep a stable temperature after only a week the veggies are frosted up. also the light at the base, not sure but I guess its just a power indicator is sometimes on and sometimes not. We have had it in two different rooms on two different circuits so I'm sure its not a power problem. Seems slow to react to temperature fluctations,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
You got two problems fisrts is a switch malfuntion getting hung up or sticky door not shutting properly. For the light. Second I am going to go with a worn or leaky seal. That is causing the frosting.
Posted on May 02, 2010
Why do both green light and orange light stay on all the time?
Without knowing much about Frigidaire , I would say at a guess that the green light would mean there is power on and the orange would be that the temperature isn't down to what you have selected yet. Most freezers have these 2 lights or a display showing the same. Check that the freezer hasn't frosted up and the food has frozen correctly. If you have a thermometer, most domestic freezers should run at around -18 degrees celcius. If its a larger type for long term storage, the freezer would normally run at around -20.
Apr 11, 2016 | Frigidaire Freezers
My freezer stopped freezing. It is running, but the food inside is not frozen solid. The electronic controls on the front are set at 0 degrees but keep flashing ff.
Can be a number of things, but the easy ones to check are;
Check that the door is closing properly and is not being pushed open by frost just inside the door or badly packed food.
Check the grills on the condenser for fluff and dust. This is generally found on the rear, or underneath hidden by a slotted grill.
If they are OK, then you need to make a service call as the fridge may need topping up with refrigerant. Could also be a fault with the defrost system sticking.
Electrolux engineer says the following
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Mar 09, 2016 | Frigidaire Freezers
Freezer door as a code of and need to set it to fc how to do
Hello Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Please allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
Jun 12, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer display flashing of and ff. I can't get it to do anything else.
Hello Aaron, thank you for allowing me to assist you!
Nov 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Of error code
Good Afternoon Jason, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Aug 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer wont go to it's normal temperature and alarm keeps beeping!
either its not defrosting or its low on freon, is there frost anywhere in the freezer, such as the back wall?
Feb 04, 2013 | Freezers
Temperature warning light came on. Removed
dear sir/madam
i think its tempretor sensor /thermostat problem please try to find thermostat needele and keep in right position , and check its tempretor satting if it,s need to reset please reset it . i hope after that it will working good. if not please try to contect your freezer maintanance perssonel for repair/reset your freezer .
hope answer the question.
thank you
please vote!
Jul 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 | Freezers
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Danby 10 cu. ft. / 283 liter Chest Freezer DCF1019W Logo
99 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Michael Van Der...
Michael Van Der...
David Jewell
Are you a Danby Freezer Expert? Answer questions, earn points and help others
