Question about Bosch 24 in. SHU53 Built-in Dishwasher
I have a bosch shu312uc with a few issues 1. takes forever to count down (pretty sure its a control module) 2. dishes dont clean - smells terrible like bad water (could this be a result of the control module??) i checked to see if the trap was clogged, it didnt appear to be. any suggestions??
  • cliffr31 May 03, 2010
    thanks for the feedback, i think its a food smell, i noticed yesterday after i attempted to run the dishwasher, when it was finished there was a build up of grime (food) along the bottom of the door that i had to remove with a kitchen knife. im not sure if it has a chopper, i will look into.
    i will grab some of the "affresh" you mentioned and give it a try anyway.
  • Rick Ead
    Rick Ead May 11, 2010
    is it a stagnant water smell of more like a food smell? if you think its a stagnant water smell at home depot they sell a product called affresh which comes for dishwashers and washermachines this stuff works so well it has removed the smell of a 1 year old burrito I found inside a unit awhile ago you may want to also check and see if your peticular model has a chopper sometimes food builds up as the chopper gets more worn down
  • Bosch Master
  • 2,605 Answers
Hello Cliff, The first thing which comes to mind when I read your post is 1) your on the right trac, and 2) this is a very common occurance with B/S/H ( Bosch, Thermador, Gaggenau ) manufactured dishwashers, a failed solder on the control board, specifically the heater relay. ( I've come across & fixed literally hundred's doing B/S/H warranty ) Both issues you mention are likely related to this since it won't heat properly. It could also be a failed "ntc" the "heating element" itself or a stuck "flo-switch" in the heater assembly, but those aren't very common and therefore unlikely. With this in mind I'd first suggest calling in an authorized bosch servicer if that is an option for you and your budget however, If you cannot afford that option or feel capable of checking this on your own, there`s a way to visually inspect the control yourself ( and ultimately repair it, see "my opinion" below ) It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish and eventually advances to "off" and ommitting the dry cycle ( on models without a display ) because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed. **My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck. macmarkus :)
Posted on Apr 30, 2010
Testimonial: "thanks guys, i will check it and let you know how i make out. BTW,i fixed my washing mach, the trap was full of ****! thanks for the help on that one"
  • Mark MacDonald
    Mark MacDonald May 03, 2010
    Hi Cliff,
    No meed to look into whether it has a chopper or not, it doesn't. No Bosch does.
    Glad to be able to help. Good luck.
    Macmarkus :)
I have a bosch front load washing machine and A green frog has gone down the water hole under the detergent drawer. There's a terrible smell. What can I do?
Google make and model number (look on the back of the machine) and get the manual.
Take it apart and clean it out.
Jan 19, 2018 | Bosch Washing Machines
My bosch dishwasher does not end its cycle
It's caused by the water not heating. You see, during the main wash portion of a cycle, your Bosch turns on the heater to heat the water, and it monitors the temperature. It won't advance until the water reaches a pre-determined temperature (145 or 155 deg F). But if the heater doesn't work, then it will stay there forever waiting for the water to heat up. (In some Bosches, it gives up after 3 hours; others it will wait forever!) But the problem usually is NOT the heater! Instead, it is the control module. If you remove the control module and take it apart so you can see the bottom side of the circuit board, you will probably find a bad solder connection to one of the relays. And if you can solder, you can fix it (temporarily). I say temporarily because that solder connection will go bad again in a few days/weeks/months. The problem is that the contacts inside that relay are bad (pitted), and that generates heat, which follows down the pin to the circuit board, and melts that solder connection. IF you could find that relay somewhere, you could just replace it, but usually I haven't been able to find it separately, and it's a lot easier to just replace the entire control module.
Sep 27, 2014 | Bosch Dishwashers
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
Run the dishwasher through a normal wash cycle with no heat/dryer time.
Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
Good luck.
Oct 23, 2009 | Bosch Dishwashers
Bad smell on dried dishes after being washed.Stale water smell.
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
My SHU53 only starts on 2Hr Delay and water is not getting hot
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Terrible Smell
Try a Quarter cup of dish washer detergent and a hot wash. this will flush out the inner bowl. Make sure you use the powder only and watch for over foaming. You might be getting a funny smell from the fabric conditioner.This stuff forms badly to the side of the bowls like glue. You couild take the bowl to pump hose off and clean the system out including the pump making sure you unplug the washing machine first. I would personally flush it out two or three times first. steve NZL, keep it simple
Jan 04, 2007 | Indesit W 123 Front Load Washer
Bosch 24 in. SHU53 Built-in Dishwasher Logo
117 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
