Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Starts fine but dies when you let off of the
Tractor starts fine but dies when you let off of the clutch or engage motor deck.
  • 29 Answers
Engage the deck very very slow at max rpm.
Posted on May 01, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Engage the blades and then drop the deckand the engine dies
Could be in safety circuit. or could be excessive load on the motor with deck running. Check all safetys, like seat switch, clutch switch, pto switch. You didn't indicate what type of tractor you have,
Jun 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Jun 08, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts fine but wheni take my footh off the clutch the tractor dies
Most of the time its the seat safety switch .
Alway engage and disengage mower deck too as there is a safety switch there too, some times its just needs moved some, its not the clutch pedal safety switch.
Feb 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower starts, but when I let off clutch, it dies.
Grass and debris clogg the switch mechinisms, safety interlocks are sometimes a pain to diagnose but I would first look at the seat interlock, the petal switch and ffinally then the mowing deck.
Dec 24, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
289 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
