Question about Hamilton Beach BrewStation 47665
It is leaking from where the coffee comes out. I think it is the rubber washer that fit inside the small grounds "catcher" that screws into the inside of the bucket.As soon as the bucket starts to fill (brew) it starts to leak from where the coffee comes out to fill your cup. I am guessing that the washer and maybe the little grounds catcher inside the pot are worn out and will not seal. Are these parts replacable?
That little screen that lies at the bottom of the bucket needs to be snapped out and the washer replaced. You have to unscrew the bottom, carefully remove the spring loaded lever, ( don't loose the spring) After fishing the lost rubber washer out of the hole, I used a screw driver or other similar item to pop the screen out. ( use care not to poke a hole in screen.) Next replace lever and spring and push the Star ended piece through the bottom and THEN fasten the washer. Replace all excess pieces and it should be fixed provided the washer isn't badly worn. This is the only way I know how to fix it after countless different web pages and searches.
Posted on Jul 25, 2010
  • kcolton Feb 27, 2011
    mrmail 2000. Thanks for the above information. Once the screen is popped out it is an easy fix.
    Kevin
  • 4 Answers
This solution worked great. My issue was the coffee was coming out very, very slowly, almost a trickle. Once I took apart the valve and popped out the screen, i found the problem. The screen was plugged with gunk. A stiff bristle tooth brush and some dish soap fixed that. To reassemble add this to the steps.
First put the spring and pivot/plug assembly back in place. Do NOT put the washer in first. ( Trust me )
Flip the tank over so you have access to the inside, press up gently on the plug and you will see the button the washer needs to fit over. It will snap in place over this button.
Check with cold water to confirm a water-tight seal. Then very carefully snap the screen cover back in over it. It is a bit stiff, but with care it will snap back in. (DO NOT USE A SHARP OBJECT)
Confirm once more you have a good seal and then you are good to go.
I ran a batch of hot water through with a little, (1/2 cup) of white vinegar just to clean out any residue.
This machine is now like new in its operation.
Posted on Apr 21, 2013
I need some rubber cup for grabber?
There are small clear colored rubber cups that are approx the same size as the rubber grabbers that are used to old things like small stained glass sun catchers on winders there usage is to be a rubber suction cup. These can be used with perhaps a small amount of alterations like you might have to snip off the part that comes down with the small hole in it to hold the metal hook that holds the suncatcher and you will have to drill a hole into the top part to attacj it to the grabber. Just find a screw that fits if you don't have the original.
Apr 11, 2011 | Ontel Products GOP2-MC18/6 Gopher 2 Pick...
I have solved the problem with the leaking k cup adaptor. I purchased a 1/2 faucet (black semi hard rubber) washer, that can be purchased at any hardware or plumbing store. On the back of the washer it...
That will work for the adapter but will puncture regular kcups. I put a 1/4 inch spring behind the gasket(delta faucet part) I had to cut it down a bit. This will make it work for both the adapter and kcups.
Dec 29, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
The round washer type piece fell out, where does it go? There are grounds in the coffee.
The Rubber Washer fits up on the needle that punchers the K-cup.
I lost the one off my machine and was getting a lot of coffee grounds
in my coffee.
I went to Lowes and picked up a 3/16T Rubber Grommet. 7/16OD x 3/16ID.
Works Just Fine Again.
Nov 11, 2010 | Keurig Elite B40 Coffee Maker
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Apr 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Feb 02, 2009 | Saeco Magic De Luxe Espresso Machine
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Leaking coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Water leaking from the base of the unit.
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
Leaks
Same problem here. I did get it apart and there are two metal water lines each connected by a rubber fitting that is just slipped on. My guess is that as the rubber connectors get old they start leaking water. I'm going to try putting a small worm clamp on the bottom half of the rubber connectors to see if it stops the leaking.
Jan 13, 2007 | Braun FlavorSelect KF 180 Coffee Maker
Hamilton Beach BrewStation 47665 Logo
1,633 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
