Question about Hitachi 46UX24B/25K 46" Rear Projection Television
Color out of line
We have a hitachi 4600cu projector tv and we get a blue or yellow haze on the left side of the screen around objects ( people ) can you tell us whats wrong and how to fix it
  • Geoff Freund
    Geoff Freund Jan 17, 2009
    There is a blue haze about a half-inch to the right of most objects, especially during a dark part. I have tried the convergence several times with no improvement. is there any other fix? Thanks!
  • 53 Answers
Sounds like a convergence problem. First, try using your set's user convergence mode.
Posted on Mar 25, 2008
I have a Hitachi 55VS69A television. I replaced the bulb and not long after I did that I had a blue haze in the center of my screen. The blue haze spread to the right hand side of the screen, and now...
I have a Hitachi Ultravision. 55VS69A. It has worked wonders but now there is a blue screen in the center of the tv. Should I just replace the bulb. thank you.
alex
Apr 19, 2010 | Hitachi 55VS69 55" Projection HDTV
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
Seeing a blue "haze" on presentations, and when on blank screen
On the "Option" menu, try selecting "Service" and the "Factory Reset". This may help. If not, you will have to use the menus to manually adjust the level of blue in the projectin. Go here for the manual for your Hitachi and you will find instructions:
http://www.aboutprojectors.com/pdf/hitachi-cp-x445-manual.pdf
Feb 26, 2009 | Hitachi CP-X445 Multimedia Projector
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Double picture on left side with red projector on Hitachi 55UX58B
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
HITACHI 43UWX10B Color Convergence
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Apr 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blue patch on left side of screen
I had the same problem with my Hitachi PJTX100. I discovered that there was considerable dust build-up inside the unit, causing insufficient venting of heat which then damaged the color prism/filter. It was close enough in time to the warranty for Hitachi to cover parts replacement (approximately $1,600). Since the repair, the blue patch is gone. I also regularly vacuum not only the outer cover but also the inner air filter that easily snaps on and off.
Dec 27, 2007 | Hitachi PJTX100 Multimedia Projector
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Apr 11, 2006 | Hitachi THE SOLUTION 3511 Projector, Mount...
Televison & Video Logo
117 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
