Question about HP PSC 1610 All-In-One InkJet Printer
When I try to use the copier all I get is rows of black lines,could this be a problem with the scanner light?
    Problem Solver:
  • 4 Answers
Yes you are correct, you are experiencing this issue due to scanner mechanism failure. scanner light have very short life.
you can try these web link to resolve this issue except of printer reset steps mention in the web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=mp-36343-1&cc=us&lc=en&dlc=en
Posted on Apr 30, 2010
Testimonial: "Thank you so much, I have been trying to get answers and all I seemed to get was back to square one!"
Why do I get a thick black line down side of page when copying, but not when I print
Not sure, but one possibility is that your paper you are copying is not all the way to the edge of the copier. If there is a crack along the edge where light from the room can get in it will show up black in those areas. You will see the same effect if you leave the top of the copier off and try to copy something. There could also be something wrong with the scanner arm preventing it from moving all the way to the edge of the window.
Mar 12, 2015 | Canon Pixma MX452
Black line scan
Most likely there is a physical obstruction to the light , it could be a small piece of paper , clip or any thing . If the scanner is completely clean , then the problem could be a damage to the scanner .
Dec 20, 2012 | HP F2110 All in1 Printer-Scanner-Copier...
A black line on the scaned page
If light going around the paper, and if upper white paper don't cover it, this part will be black. Try to cover with some part of white paper around. If you have black line in the middle of scan, you have hardware problem with scanner (or old buggy driver). Try to update scanner driver.
Aug 24, 2011 | Office Equipment & Supplies
Hello! 1999 plymouth voyager instrument cluster not working! Wat is the problem?
Instrument panels are computers in them selves. it could have blown. check fuses and have it put on a diagnostic scanner and checked for any codes
Jun 16, 2010 | 1999 Plymouth Voyager
Black row are comeing for scanning
its one of 2 possibilities
If you are getting black lines down the page, then you have a bad scanner assembly. It will be too costly to replace.
if you happen to be using a document feeder which i dont believe so, you might have some dirt in the scanner glass that needs cleaning.
thanks adi
Apr 21, 2010 | HP ScanJet 2400 Flatbed Scanner
Fax sent and copy has a 2 inches black belt on left
This is scanner defect. You could have a scrap of paper or something in the slot where your documents are fed in but I suspect that the scanner led array has a few bad led's and that is what is causing the black line. When your original is fed in there is a "light bar" that lights up to scan the original. This light bar is made up of a row of small led lights. I have seen these led's loose connection so that a few do not light up and this causes the problem you describe. They are usually repairable but the problem is you can replace this fax with a new one for under $100 and the repair most likely will cost more.
Dec 25, 2009 | Brother FAX-1020 PLUS Plain Paper
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Front Panel (LCD screen) only shows black boxes
From what I am reading, Try this.
Go to Xerox.com,
then click support and drivers.
Enter phaser 6100 in the search box.
Then once at the 6100 options, click drivers and downloads and then download the Firmware version 1.05 and reload your printer software.
May 04, 2008 | Xerox Phaser 6100/BD Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
