Question about Dishwashers
Upper Rack not cleaning
The upper rack on my dishwasher is not being cleaned. A greasy film is left on everything and all food items are left on dishes. We have removed the upper rack spinning arm and flushed it out and it is still occuring.
  • 2 more comments
  • KansasMay Mar 25, 2008
    It is a Whirlpool Quite Partner 2, model #DU1100XTPQ0
  • deharvey Mar 30, 2008
    upper dish rack has greasy film left on dishes after dishwasher has been ran
  • Anonymous Mar 13, 2014
    Upper rack not cleaning
  • Anonymous Mar 20, 2014
    how can I add height to bottom rack as 10 inch plates can't clear the rotating arm from upper cleaning rack
    President:
  • 2,651 Answers
Id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Posted on Mar 25, 2008
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag model no mdb8951aws. My dishwasher doesnt clean properly. There is a residuesomehing like food stuck inside cups & bowls specially in upper rack .i dont stack dishes.tried everything but no...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
][\][\0-0-
Jul 05, 2010 | Maytag 24 in. MDB8951AWS Stainless Steel...
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Feb 04, 2010 | KitchenAid Dishwashers
Residue and food particles left on dishes in upper rack.
Check the inlet screen at the bottom of the dishwasher that could impede the flow.
Otherwise the pump may be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore HE2 Plus Front Load Washer
Film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishes not cleaning particularly on top rack
A guess: the solenoid that directs the water from the pump is not opening fully. Clean it. It is a little nasty to get to but will likely cure the problem.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
701 people viewed this question
Top Dishwashers Experts
