I bought a 55 inch Rear Projection Mitsubishi HD TV yesterday 2002 year, It worked fine at the guys house but now today since I got it home the picture has a couple flickering lines on the screen in all the AV's and all the menus. The only thing not flickering is the DTV antenna menu, the DTV component however is flickering. Please help
  • goodnightgal Apr 30, 2010
    Where do I locate the AV board and optics engine. There's alot in this TV. Thanks
  • 19,396 Answers
The AV board is the board connecting to the external cable/antenna on TV. It cannot just be replaced like that . It must be tested and eventually replaced by a technician.
Try connecting to an external DVD. If the external DVD does not flicker and is OK, just get an external direct TV box that is working. Call DTV to get one.
If the external dvd is flickering with the DVD, test a differnet connection cable. In that case internal parts must be tested, and the job is suitable for a technician.
Start testing with different cables, external DVD or console, and eventually get a new DTV box.
See : DIRECTV: Contact Us
Please do not forget to leave feedback.
Regards.
Posted on Apr 30, 2010
    Genius:
  • 1,112 Answers
Hi:
If you mived the set yourself, then you might want to have someone or yourself open the unit and make sure no boards popped out of its connections, especially the A/V input board, this could of been done while moving the set or during transportation, check all connectors to make sure none of the connecting plugs have come partically out of their sockets, the bumpy roads and pot holes may of jarred one or two loose. Especially check around the Optics engine assembly for loose connections. My best guess at this point is the A/V board area where this board connects to the main signal board.
  • Lavell Turner
    Lavell Turner May 03, 2010
    Hi:
    The A/V board is the board you make all the input connections to such as the DVD etc.
    The optics engine is usually in the center of the television. I don't suggest you remove the optics engine unless you have knowledge of how its done. I would suggest you just take a close look around inside the set to see if any plugs have came off or slightly dislogged itself and make sure all boards are seated firmly.
I just bought a 55 Inch Rear Projection HD Mitsubishi TV. 2002 model year. It appeared to work fine yesterday at the guys house before I bought it then I brought it home and I have a flickering going on....
It's not a banged-out connection, something is wrong with the analog inputs (and only them, the rest of the tv is ok) - probably caused by a faulty capacitor either in the corresponding power line or the signal path itself, normal problem for a tv of that age. You will gonna have to open it and see where the problem is.
Apr 29, 2010 | Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
The best ways to move my 55 inch Mitsubishi TV to another home?
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Aug 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
