Question about HP Compaq 1520M (Carbon, Silver) 15" LCD Monitor
Have a usa power lead want to fix a u.k plug to it but wires are two black one green
  • 11,361 Answers
If you look at the power cord, one side will have ridges, and side will be smooth.
The one with the ridge is Neutral (same as Blue wire for Neutral used in Europe (White for US)), the smooth one is Line (same as Brown wire for Line (hot) used in Europe (Black for US). The Green is Earth safety Ground (same as Green with Yellow stripe as used in Europe).
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 30, 2010
WHY2003 BLAZER ALL POWER WINDOWS NOT WORKING?
A wiring problem or the driver's master switch, probably. Check for broken wires in the harness going into the driver's door opening. A dark green wire is the power wire to the switch (from a 30 amp circuit breaker in the relay block). and a black ground wire from the switch going back into the cabin.
Pull the master switch out and check for power on the dark green wire at the connector, with key on. If no power, wire may be broke from the circuit breaker to the switch, probably in the door opening. If power is good, check the ground circuit from the switch connector to ground. Like this: voltmeter positive lead on the green wire terminal with key on, voltmeter negative lead on the black wire terminal. If voltmeter registers battery voltage, power and ground is good. If no voltage shows on voltmeter, power or ground is bad. Move voltmeter negative lead to a good ground on frame or body. If voltage shows, power is good and ground is lost-look for broken black wire in door opening. Check for the black ground just inside the cabin from door-maybe under the driver's kick panel.
If both power and ground is good to the master switch, try a new or used master switch.
Jun 08, 2014 | 2003 Chevrolet Blazer
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I need to know the color coded wires for a car stereo, pioneer deh1500. whats speaker colors, power colors and constant power
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
Dec 09, 2009 | Pioneer DEH-1500 CD Player
Replace power switch
No, The Green wire or wires are ground and go directly or in-directly to the frame or casing.
The White and Black are your two outside leads.
One is neutral and the other is hot.
If you run the green wire to either of these two leads, you will have a major problem..
Nov 15, 2009 | Computers & Internet
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Have European Swarovski chandelier wblack/brown pair wire, green and blue separate wires, need to install in USA
This will probably take a meter, first prove the green is ground with an ohm meter from the green lead to the frame or case, if so, we know what to do with that.
next, I need ohm readings between the remaining three leads with NO POWER and switch on.
For example between black to brown 10 ohms, from blue to black 5. from blue to brown 5 ohms, whatever it is, or if they have no connection at all.
From there we have a good start.
Will
Nov 01, 2008 | Kitchen Appliances - Others
HP Compaq 1520M (Carbon, Silver) 15" LCD Monitor Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
