Question about HP Laserjet CM2320nf All-In-One Color Printer
HeLp! My HP CM2320nf MFP is printing blurry!
HeLp! My HP CM2320nf MFP is printing blurry on only half the page when I print in color. Tried calibrating, and realignment. Didn't work.
  • pokerpjf Apr 30, 2010
    Thank you for responding. It is not just one color. I have what looks like 3D printing...? I see the print of every color, one just a little off from each other color.
    The blur starts at the left side of page and gradually gets more noticeable as you look to the right side.
    Always in color.
    Page count? Do you mean how many pages does printer have so far on those cartridges? Or, how many pgs does printer tray hold?
  • brett207
    brett207 May 11, 2010
    Need more information, Is it one particular colour that blurs? Is it along one side or the leading or trailing edge? Is it always colour? What is the page count of the device...
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Posted on Mar 08, 2011
    Problem Solver:
  • 19 Answers
This is nowhere near the solution. I have seen this twice. It occurs when the Magenta and possibly other laser mirror assemblies are misaligned. Disassembling this monster is a monster job. It also means that you must have the Service Manual and great patience and skill, as the manual is not very detailed or thorough.
Posted on Aug 04, 2010
  • Zenbob Oct 19, 2010
    The actual solution is a bit surprising. Replacing the formatter board solved the problem on two machines! Same cartridges, same fixing/fuser unit. Thoroughly clean the printer, replace the formatter board and the result was a dramatic. Remember, it is the formatter that arranges the image content, and processing for image data to each laser/cartridge, and even print density.
    I hope this helps others!
    New Friend:
Hello ,
My printing Machine LaserJet M1213nf MFP the Error is Automatic printing. Please Advice
Posted on Jun 17, 2013
I had the same problem and it turned out that I had a defect toner cartridge. Try to find out if there's one color that's much more misaligned than the others (in my case: magenta) and replace the cartridge. Then calibrate the printer until colors are aligned correctly again (I had to calibrate 4 times).
Hope this helps!
Posted on Oct 19, 2010
  • 231 Answers
Hmmm,
from your description, it sounds like it could be a fault in the fixing unit...
try this,
start a print job from tray 1, and just as the tail end of the sheet disappears into the printer, open the main front door.
Have a look at the partly processed image on the sheet of paper. Does it look ok? It may appear a bit dull and powdery, but is the image correctly aligned?
If it is, then the blurring and smudging is happening during the fixing process in the fuser assembly. Replace the fuser kit.
If the image is not correctly aligned, then you will need to either check the error log page for CPR errors, clean the registration sensors or replace the transfer kit.
Posted on May 03, 2010
How can i refill my hp color laxerjet cm2320nf mfp
Look online for refill kits. There are many to choose from
Aug 10, 2016 | HP LaserJet Office Equipment & Supplies
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
Is there anyway to print onto A7 size paper on this printer?
yes-
you can print 2 A7 pages onto 1 A6 page and then manualy cut the page in half- hey presto 2xA7 prints
Dec 11, 2013 | HP Laserjet CM2320nf All-In-One Color...
Quattro pro x3 can't print
unstall the driver from control panel and install afresh.
Nov 15, 2012 | HP FACTORY RECERTIFIED COLOR LASERJET...
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Cp2320 mfp printing blank pages.
hi
Try the following
1. Open the printer remove all of the cartridges and re insert back and try to print.
2. Try to see if the laser scanner shutter is getting opened as you close the front door the mechanism needs to open the shutter for laser to hit the OPC drums in your toner cartidges.
RATE MY SOLUTION
Jun 29, 2011 | HP Laserjet CM2320nf All-In-One Color...
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
Envelopes print crooked
A decent printer should print a #10 envelope without a problem. If this model won't do so, return it and get another printer. Suggest Epson or Canon -- AVOID HP printers.
Oct 10, 2017 | HP Laserjet CM2320nf All-In-One Color...
HP Color LaserJet CM2320 MFP shutting off and on -does not work
unplug the telephone and network cable and restart the printer.
Dec 11, 2009 | HP Laserjet CM2320nf All-In-One Color...
HP Laserjet CM2320nf All-In-One Color Printer Logo
3,954 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
