Question about Frigidaire FEQ1442ES Electric Dryer
The drum turns but does not dry or does not heat up.
  • 1,998 Answers
Check your relays and fuses to see if you have continuity with the power off also check the heater to see if you have continuity on both sides lastly check the motor should be a relay these short out due to things like lint its actually a more common thing to have to replace a relay or fuse inside your dryer
Posted on Apr 30, 2010
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 | Cell Phones
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Dryer doesnst dry
Is the drum turning? Open the door and press in on the switch and start her up. See if the drum turns is what I would try.
How to get inside and diagnose with videos and more for American dryers
Dec 30, 2012 | Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
HEATER ELEMENT DIED. DRUM TURNS, NOTHING DRIES.
Sounds like it. Very easy to change.
May 25, 2009 | KitchenAid Dryers
Not drying
is it electric?is the drum turning/are both your vent holes(wall&dryer)clear?mike
Mar 21, 2009 | Kenmore Dryers
The tumble dryer does not dry The heater element warms up The fan motor is turning but no heat gets into the drum. Bosch Classixx wash and dry
does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Oct 27, 2008 | Bosch Washing Machines
Drum is not turning. Heat works
Sounds like the belt has broken or come off. This is usually inexpensive to fix. You just need to get it out in the open to replace.
May 25, 2008 | Asko T761 Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
105 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
