Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Error code dL
Has anyone had this error code? I tried clearing the code and nothing is blocking the top of the washer to prevent it from locking....help!!!
  • Anonymous Apr 03, 2008
    I just had the same problem starting Monday, March 30th. This is the 2nd problem since I bought this machine 8 months ago. The first code was sd and took forever for it to be solved. Can I fix this without a service call?
This means door latch failure. it has to do with the magnet. need a new part a door latch or new board. very expensive.
Posted on Apr 01, 2008
  • 185 Answers
Its a door lock faliure all the error codes are in your use and care guide
Posted on Mar 26, 2008
SOURCE:
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
What does code dl mean
The "dL" error code means that the door/lid can't lock. Check to make sure nothing is stopping the lid from closing and locking. If everything looks ok, then you either have a bad door lock or a bad control board.
Jan 10, 2012 | Maytag Bravos MTW6600T Top Load Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a code of dl when i start it up...than it just peeps and nothing else happens
dl means door lock error you have to replace the door lock switch cheapest supplier might be marconeappliance parts
Aug 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Washer , Model 11027062600 , top loader
A Drain Limit, I suspect. I see these codes but haven't been able to find a legend or anyone that can confirm what it is. Does the tub sit with water in it and it doesn't drain?
Try turning it off and back on. If that dosnt do it try unplugging the machine and back in then on.
Is the Drain line kinked? Does the motor turn and run?
If this helps you please rate me accordingly if not please post back as to what DL is if you find out. THANK you.
Jul 12, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
850 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
