Question about Kodak EasyShare C713 Digital Camera
I just placed new batteries into the camera and it won't turn on It is a kodak c713
    Problem Solver:
  • 19 Answers
Hold the swich
Posted on Apr 30, 2010
I can't find my disk to download my camara on my new computer. Where do I go to download it from your site? Kodak easyshare C713 C813
http://support.en.kodak.com/app/home/selected/true
You'll find links for "Downloads and Drivers" and "Installation and Setup" along the right side.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )..
Aug 05, 2011 | Kodak EasyShare C713 Digital Camera
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
Dec 31, 2009 | Kodak EasyShare C713 Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
Even using new batteries the camera just wont turn on - kodak easyshare c713
Are You using the AA batteries?
Try to reverse the oirentation of the batteries, Instead of positive negative make it negative positive. I also have this problem same camera model what I did is that reverse the polarity of the battery,
MAke sure that you are using the recommended battery, If disposable you can used AA Alkaline and if rechargeable you can use KAA2HR battery or Ni-MH battery
Nov 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
My EasyShare C713 won't turn on even after I insert new batteries
It could be something more serious, but this problem is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 05, 2009 | Kodak EasyShare C713 Digital Camera
Kodak C713 dose not turn on back.
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 25, 2009 | Kodak EasyShare C713 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
Kodak EasyShare C713 Digital Camera Logo
152 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
