Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a 22hp intek v twin briggs motor while cutting it just stop now its making a popping noise when trying to start and it wont start just spinning and popping
    President:
  • 2,468 Answers
If its popping out the intake or exhaust,then possibly you have sheared a flywheel key and its out of time,you need to remove the flywheel cover and look to see if this is what happened
Posted on Apr 29, 2010
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22hp bs wont idle
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 22, 2012 | Briggs & Stratton Briggs Stratton Intek V...
What is the high speed rpm setting for a intek 22hp vtwin?
Generally 3,600 rpm is the high speed setting for many of these type of engines.
Mar 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton Intek V twin 22HP motor misfires.
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp not charging
if you have ever let the motor run whilethe battery is disconected even for afew seconds you will have burnt out the recterfier and there will be no chargeing of battery until the rectifier is replaced it is situated under the flywheel on top of the motor
Jul 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
982 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
