Question about Razer Tarantula RZ03-00070100-R2U1
Razer Tarantula, settings don't stay.
This has just been hell, I've tried calling razer, they didn't help, they "escalated" it by sending a brief email to tech support. I've been answering stupid questions via email for about 2 days now, and they aren't any help.
So basically, I'll give an example of what the problem is.
Say I want to set the L1 macro key to something; I input what I want it to be, I click Apply, and then Ok. I am now back at the main config window. What I have input for the L1 key shows up in there. I click Apply and Ok again to get out of the main config window. I go back in my game and try to hit the key, it doesn't work. So I open the config window back up and what I had set for my L1 key, is no longer there.
(It's not just the L1 key, that was just an example; nothing works.)
Something else I've noticed is that it ALWAYS stays on profile 5. I can switch it, but then when I hit Apply/Ok, it just goes back to 5. I'm running on Driver Version v2.10 and Firmware Version v2.00. I have tried different driver versions to see if it was just a version in particular. I've tried updating my firmware, but every time I try, it just tells me that it failed, and to unplug and replug in my keyboard. Which obviously does not make it work. I've also tried my keyboard on a different computer, and the same problems are occurring, and I also cannot update my firmware via that computer either.
Another thing I've tried is uninstalling and reinstalling everything for the keyboard, making sure that I restart my computer when prompted in the setup. But that doesn't change anything, the problem still exists.
My OS is Vista.
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
I cant move my razer naga mouse top and buttom
Try cleaning the lens with some Windex or any other cleaning spray. Not too much, you don't want liquids in the mouse.
May 20, 2012 | Razer Naga MMO USB Laser Gaming Mouse -...
My media player keys on razer tarantula keyboard
after i checked the preferences in winamp i found out my hotkeys were not enabled so thats why they were not working. So if you have the same problem go to preferences -Global hotkeys and check the 2nd box
Mar 18, 2010 | Razer Tarantula RZ03-00070100-R2U1
Keyboard keeps highlighting everything makes it imposible to type anything out checked out mouse and that is not the problem can unplug keyboard and problem stops
I would check your Shift keys and see if they are sticking. Try pulling up on them. If you determine that they are the problem, you might need to disassemble the keyboard and clean the keys. Good luck!
Mar 09, 2010 | Razer Tarantula RZ03-00070100-R2U1
I want to find code to unlock my motorola razer
Usually it will be 1234 or last four digits of your phone number, if it isn't try calling your provider, they should be able to help you.
Oct 06, 2009 | Motorola Mobility RAZR V3
Tarantula does not work in POST
Make sure you have the usb keyboard option enabled in your bios
Good luck
Jun 22, 2009 | Razer Tarantula RZ03-00070100-R2U1
My W don't work right, I have to press it really hard and sometimes it just stops to work
Hello , maybe your W button is out of work pf bad use, so its time to change your keyboard ^^
Jun 11, 2009 | Razer Tarantula RZ03-00070100-R2U1
O button doesn't work properly
Well i started having the problem with the letter 'B' so what i did was i took the key out and i placed a small square bit of tissue paper under the key now it works fine....... although this shouldnt happen with such an expensive keyboard. Im never buying a razer product again.
Nov 11, 2007 | Razer Tarantula RZ03-00070100-R2U1
Keyboard Razer Tarantula doesn't work
i tried to install the same keyboard and im having the exactly the same problem. i had a saitek eclipse before and it worked perfect. but now nither works and i uninstalled my mouse on accident as well so now im totally screwed
Nov 02, 2007 | Razer Tarantula RZ03-00070100-R2U1
Razer Tarantula RZ03-00070100-R2U1 Logo
78 people viewed this question
Top Razer Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Avishek Samaddar
Avishek Samaddar
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
