Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Ice cube maker not making ice - Maytag MFI2568AE Side by Side French Door Refrigerator
  • 1,998 Answers
Feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
Posted on Apr 30, 2010
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ice maker quit making Ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | Maytag MFC2061HES Stainless Steel French...
Not making ice cubes
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
375 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
