Question about Philips 42FD9954 42 in. Plasma HDTV
Any ideas? Model - 42FD9954 philips 42 inch plasma...upon powering on the screen goes on for a second the relays click and then the screen turns off and the red LED blinks constant...I researched this problem and was recomended to replace the PWM IC and a few electrolitics but i still have the same problem...
    Sergeant:
  • 395 Answers
1) Replace C2663 by 2020 021 91677 (100uF/50V, 105°C).
2) Place Schottky diode 9336 247 60133 on pin 7 (+) and 8 (-) of IC7650,
to avoid negative pulses, resulting in this bad startup behaviour.
Posted on Mar 25, 2008
SOURCE:
Model:Philips 42PF9965 Plasma At switch on the green light comes on for a few seconds,then it goes off and the red light starts flshing.After several attempts the tv may come on live and stay on until you...
You might have some swollen capacitors on your power supply board. They will be easy to spot out, because they will not have flat tops like the rest of the capacitors. Replace them with the same rating capacitor. You will need a soldering iron, solder and solder wick for this repair. If you are not comfortable with electronics I would recommend taking it to a authorized service provider.
Apr 14, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Philips Plasma NO LIFE
Are all the caps good on the PSB.? Most sets have Samy boards and they used very shotty capacitors. Some show NO visual clues of being blown as in poped at the (X) top. They just vaporize/dry out. Do you have a cap tester?
Best Regards and Semper Fi
Feb 08, 2009 | Philips 42FD9954 42 in. Plasma HDTV
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Power issue
The Philips Plasma TV have a problem with electrolytic capacitors going bad. I believe you heated some capacitors and your problem may return. If so, try replacing 2540 ([email protected])
and 2508 ([email protected]).
Apr 11, 2008 | Philips 42FD9954 42 in. Plasma HDTV
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42FD9954 42 in. Plasma HDTV Logo
297 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
