Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
When you turn it on it goes right where you would click on user to get on but instead it has a black screen pop up then operaiton system not found turn it self off
    Problem Solver:
  • 6 Answers
Operating system not found means that there is an issue with Windows. Restart the machine and keep tapping F10. Get into the BIOS and then go into the diagnostics tab. From there run the harddrive test. if it passes, then you just need to re-install windows. You can call HP to get a replacement disc at 1-800 HP INVENT (you just need to pay shipping). or if it fails you will need a harddrive replacement. This might be covered under warrenty if you have one
Posted on May 02, 2010
  • 54 Answers
This may be a h/w failure. go to bios and run the hdd test from the diagnostic option. if it says no ide device found, reseat the hdd and turn it back on. if its still the same. replace ur hdd.
Posted on Apr 30, 2010
  • 47 Answers
You have lost your os. try booting with cd. you may need to change your boot order
Screen goes black unless it's on charge, even though it's fully charged
Right click on the battery icon in the taskbar (Normally located near the clock, bottom right corner of the screen).
In the sub-menu that pops up, select "Power Options".
Next to the power plan you are running, to the right of it, click on "Change plan settings".
Scroll down to and click on "Display" and you will see the computers setting options for both "On battery" and "Plugged in" with the screen turn off time in drop down boxes.
You need to select what time the screen turns off in when no user input is detected for that time. I usually select 5 mins for battery.
Hope this helps, and wishing you a Merry Christmas. ;)
Dec 15, 2013 | Computers & Internet
Screen goes black unless the comuter is on charge, although it's fully charged
Right click on the battery icon in the taskbar (Normally located near he clock, bottom right corner of the screen).
Dec 15, 2013 | Sony Vaio Duo 11
Instead of screen saver coming on it goes black i have a hp persario cq2 and windows 7 i am running mozilla fire fox
1. right click desktop and go to personalization
2. click screen saver
3. change your screen saver to "none"
4. click on power management
5. click on adjust settings
6. change both options to "never"
7. click save and okay
Aug 27, 2013 | Microsoft Windows Vista Home Premium with...
Black screen with cursor on dell inspiron 1545 after asking for user
Step 1:
make sure your graphics card is securely seated with no dust in its socket if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
Feb 15, 2013 | Dell Inspiron 1545 Notebook
I keep recieving a pop-up window which states: KEY:"HKEY_LOCAL_MACHINE\"Value:"ConfigDir" not found in the registry. then I will click okay and then anouther box pops up... The...
There are few registry keys on your computer which are either being deleted or are infected and then you keep getting these prompts on to your computer. There are few work arounds that you can try.
1. Try to take your computer to day before which you are facing this problem by performing an system restore.
To perform system restore follow the steps below
Go to All programs/ accessories / system tools / system restore
2. Create a new user account
To create a new user account try the below steps
Go to control panel / Users / Create a new user / choose an Adminstrative account / Give a name and click on ok
Click on start / switch user / Choose the new user account which you have created
Jan 06, 2011 | Computers & Internet
I changed some setting for the computer resolution and now my monitor just says no input signal..the hard drive turns on and then goes into sleep mode and says no input signal. How can i fix this problem?
Possible reason is that input signal goes out of range that probably a Screen refresh rate that the monitor cannot handle. Instead of bursting into flames, the monitor shuts itself
down as a protection feature. Look at the monitor manual if you got one.
Safe Mode should allow the monitor to work in the problem account.
Try this.
Boot in Safe Mode (see below)
Switch users to the problem account
Right click the desktop
Select Properties
Click the Settings tab
Click the Advanced button
Click the Monitor tab
Select: Hide modes that this monitor cannot display
Select a different Screen refresh rate
Click Apply twice and then Click OK
Or try this:-
power on the system and press and hold F5.
When a screen appers with some option, try to find a option something realted with VGA setting.
Click that option and let pc start normally.
It will surely work
Dec 10, 2010 | Hannspree HW191D LCD Monitor
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
Laptop screen goes blank randomly
Hi you can try this in Vista
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
  3. If you are prompted by User Account Control for permission, click Continue.
  4. At the command prompt, type the following command, and then press ENTER: powercfg.exe -h off
  5. Type exit, and then press ENTER.
Windows Xp;
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options. click the Hibernate tab and unckeck the box and turnoff monitor should be never
Sep 16, 2009 | Acer TravelMate 5520 Notebook
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Display Screen goes black
Right Click on Desktop
select Properties
select the Scree Saver tab
Click on the Power Button which is on the right side
select the power schemes
In that select the power schemes options and choose "Never" for turn off monitor, turn off hard disk and system stand by
click on
Apply
Repeat the above step for each option in "Power Schemes"
then click on ok
Feb 15, 2008 | Compaq Presario 1200,1600, Series CD...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
