Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Lights will turn on and off manually only
Transformer seems to work OK. Lights will turn on and off manually but clock is not turning anymore. Landscaper installed over 1 year ago. He also installed it in the garage. Is this considered "outdoors”? Box says Intermatic Heavyduty cannot see any numbers but casing is plastic, otherwise looks like this clock. Questions in short - does timer need to be replaced? Does placement need to be changed?
  • Anonymous Mar 24, 2014
    Timer lights 1 & 4 are on constantly & nothing else works. I've tried unplugging it but still no change. I bought it from garage sale (1 year ago) with no manual, it's been working great up til now
  • 623 Answers
Just checking, still plugged in, fuse or circuit breaker not tripped that provides power to it? If you can turn it manually, and the dial does not turn when powered up, look for a small on/off switch, other than that, maybe it does need replacement, but they usually last longer that a year, but I have had some timers that just quit working on me too.
Posted on Apr 30, 2010
Timer rotates but whenever it reaches the tripper to turn the lights on it gets stuck there. It's like there isn't enough power to rotat the switch to turn the lights on. Have checked the switch...
The clock motor gets weak and sticks on the tripper and then stops working.
Possible solution: Some people report they disassembled clock motor, cleaned the gears and added a bit of vaseline or white grease to gears because they get dirty.
Then afterward, you might try duct tape to seal unit from dust
Others report they got the clock motor apart and didn't mark parts and take photos along the way, and forgot how tiny gears went back.
My experience with clock motors, and motors in general, is when they slow down, they overheat and don't last much longer.
There are no replacement clock motors for ML series power packs, which is shortcoming since Intermatic makes replacement clock motors and modules for many of their products.
Work-around: Set timer to override, then plug power pack into cheap wall timer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Jun 26, 2011 | Intermatic Malibu 300W Power Pack...
Power transformer if change from 50 hz to 60 clock
Is that a question or a statement?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-ICF-C212-Clock-Radios-manual/id/267ag023/t/2/
Considering a 9VDC battery keeps the clock alive when power is disconnected, I would guess the clock time is independent of line current frequency. Does anyone actually use motorized clock works anymore?
Feb 19, 2011 | Sony ICF-C212 Clock Radio
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Nov 29, 2010 | Intermatic Malibu 121W Power Pack...
Subaru Forester 2001. Parking lights stay on when car is turned off. Lights go off only when fuse removed. Light switch on steering column was changed to no effect. Separately, AC, fan and heater...
I have had the parking lights on my 1998 forester stay on w/ no way to turn off. Used the remote door lock to lock and unlock car and the lights went off?????????? This has happened twice with the same solution
Nov 26, 2010 | Subaru Forester Cars & Trucks
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning...
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
May 25, 2010 | Intermatic Malibu 300W Power Pack...
All of a sudden my radio stopped working. The clock or any lights do not come on anymore. I only have 38,000 miles on the car. Any ideas what might be wrong? I looked at the fuse, and it seems to be OK....
i have had that happen to mine, i had to turn on my lights and it worked, dont ask why but the 2 times it had happened to me the radio would work
Feb 27, 2010 | 2008 Dodge Avenger
Malibu Light Transformer ML121RT troubleshooting
1) Disconnect the plug.
2) Remove the 3 hex screws holding the cover.
3) Make a note of all connections (taking a picture is even better).
4) Connect the black power wire to the red transformer wire.
5) Connect the white power wire to the white transformer wire.
6) Set your voltmeter to 20 or 50 volts AC (not DC and not less than 15 volts).
7) Plug the transformer in the wall.
8) Test the voltage coming from the A & B connectors at the back (polarity is irrelevant).
If you see 12 volts or thereabout, the problem is with the little switch (the one with the black and red wires that is activated by the trippers on the clock dial). I have the exact same problem but I have been unable to locate the part so I am going to try to clean the contact points and see if that works.
Jun 22, 2009 | Malibu Intermatic Inc. ML121RT Low...
I cant get it to turn on
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 23, 2008 | Jenn-Air ® 48" Professional Over The...
AWR1-1W
check the rectifier next to the transformer, the dc out should be around 15 volts and the big main cap as well.
mosfet guy
Jul 21, 2008 | Bose Wave Radio
Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Sep 23, 2007 | Aiwa PX-E860 Turntable
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
495 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
