Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Honeywell RTH 7500d is not working.
I have a honeywell RTH 7500d. All the wires are installed per the install guide. Red to R, with jumper to Rc; blue to C; orange to O; yellow to Y; green to G, and white to W2/Aux, with jumper to E. Once I plug the t-stat back in, I can't get any cooling, heating, or even the fan on. I've gone through and set all the settings, and still nothing. Thanks!
  • cfarmer60 Apr 30, 2010
    heatman101, thanks for the response. I did that last night with the volt meter, and it measured nothing. I think I created the problem earlier. I tried to install a honeywell rth6400 tstat, which I later found out was not compatible with my system since I have aux. heat. Turns out, I wrapped the O, B, and W wires together and put them into the O/B terminal. That may have blown it.
    The power was off when I did the hookups, so it must have blown it when I flipped the breaker back on.
    Now I think I need a transformer, and that is over my head.
    Thanks again.
  • Honeywell Master
  • 43,501 Answers
If nothing is happening then I am wondering about tje power... If you have access to a digital meter, you should have 24v a/c across the R wire and the C wire...
Did you make sure to turn off the power at the air handler or furnace before unhooking the wires at the t-stat??? If not then you have blow a fuse in the control board or burnt out the transformer...
If you have power on R then jumper to G and the fan shoudl come on... if it does then the t-stat is bad...
This should give you a few things to try and is what I would be doing if it were my service call...
heatman101
Posted on Apr 29, 2010
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I replaced the thermostat with a new Honewell RTH 2510B model. Before I replace the thermostat, the AC repairman added the booster to the compression since he said that was the problem why it does'nt...
Check at the furnace there is a 3 amp fuse on the circuit board you might have blown it when you installed the t-stat without shutting power off to the furnace. Also make sure RH and RC are jumpered together Y= cool G=fan W= heat R=power. let me know ok
Jul 25, 2011 | Honeywell Heating & Cooling
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
Installation manual (pg. 6-7)states - "Remove Jumper if you have both R and RC wires" I only have the 'red'. But with the jumper in the way I can't get the red wire into the 4th terminal. So should I...
No keep the jumper, you should be able to get the red wire in under the little peice of mettal that the jumper is under but just on the other side of the screw, The red wire can go on either the Rh or the Rc terminal along with the jumper. If all else fails just put a wire under Rh and another wire under Rc and then wire nut the red Rh and Rc wires all together.
Nov 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH 221 Programmable Thermostat. Jumper missing
The proper way to do it would be to use a small piece of wire stripped at the ends. Then use a small amount fo solder on each end to connect RC to RH. Or use a small piece of solid(stiff) wire and strip the ends. The wrap the ends around the connector and crimp them to make contact. I would not use a paper clip. A paper clip is not designed to carry 24volt current and could melt.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Need help with wiring thermostat
first do you have a heat pump unit or standard a/c? standard a/c connections at the thermostat go like this red wire to rh-rc which is the 24v power and you don't have to remove the jumper.white goes to w which is the heating wire yellow goes to y which is the cooling wire green goes to g which is the fan wire and blue goes to c which is the common wire. so if your stat has rc- rh ywgc you should be set if the wires on the furnace correspond with the same alpha designation.orange may be used if u have a heat pump unit otherwise it may just be a spare you cap off and leave behind the subplate.
May 31, 2009 | Honeywell Heating & Cooling
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
348 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
