Question about Kenmore 24032\24036 Top Load Washer
Kenmore 400 series stops on the rinse cycle full of water
  • Rick Ead
    Rick Ead May 11, 2010
    see if you can set the machine to spin and does it agitate? if it is not spinning and does not agitate first thing to check is the lid switch open the lid and listen for the clicking sound as you open and close the lid if the lid switch passes your inspection if it does not pass your inspection a cheat to the lid switch is using a jumper wire on the connection between position 1 and 3 on the terminal end
  • 5,911 Answers
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 30, 2010
Thank you so much! Your advise on the advice on the lid switch was exactly what I needed to fix my washer! I wish I would have checked your site before hauling 3-5 gal buckets of water upstairs. One note, on my washer the lid switch was activated by the left hinge arm. In my case the switch was fine, but the screws had fallen out of the hinge so it wasn't contacting the switch firmly when the lid closed. Thanks again!
Posted on Aug 20, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Posted on Aug 19, 2008
  • 351 Answers
SOURCE: Our Kenmore 70 series toploading washer now stops
is the lid switch any good? whirlpoolpartssurplus.com i can send parts to you with free shipping!
Posted on Jun 26, 2009
jsrock516
  • 5911 Answers
SOURCE: My Kenmore Series 90 Washing Machine water will not stop filling.
This problem is commonly attributed to either a water inlet valve that doesn't shut off, or a pressure switch malfunction. The following links explain how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
If the washer is not overflowing, the likely problem is the water inlet valve. If the washer fills to the point where it overflows, the easiest and most common cause of this problem is the small plastic air hose on the pressure switch coming loose. It can usually be fixed by simply reattaching the hose. However, read through all the information provided and double check everything to make sure.
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 02, 2010
tiger56h
  • 176 Answers
check the lid swetch
Posted on Sep 21, 2010
  • 385 Answers
SOURCE: My kenmore 400 top load
Sounds like you have a bad water valve. It has to be replaced.Hope this helped.
Posted on May 10, 2011
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Our Kenmore 70 series toploading washer now stops mid-cycle (before the rinse cycle) full of water.
Jun 26, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
1,400 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
