Question about Frigidaire FEF352 Electric Kitchen Range
I'm getting an F9 error, how do i reset it. I was trying to clean the oven and i mistakenly opened the door. It started beeping and gave me an F9 error
Our door lock was rusty and crusty... It locked halfway and froze.
I worked it with pliers until it was back in the open position and cleared the F9 code.
Won't clean, but we can use the oven.
It's the day before Thanksgiving, btw.
Posted on Nov 26, 2015
  • 15,935 Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$#%@#$%
Posted on Oct 01, 2010
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Set oven to clean, get flashing door indicator lig...
If this is an Electrolux oven then F9 relates to micro-processor resets itself.To get this to reset fully its reccomended that you disconnect the unit from the electric supply and then reconnect then retry.
Hope this helps
May 10, 2010 | Ovens
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
Jan 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire Range FEF357BBD error code F9
I had the situation where the oven thinks the door is locked but it was not locked. Setting and holding clear eventually gave a f9 error.
I solved this by turning the circuit breaker off and taping over the oven light switch ( so it thinks it really is locked ) and turning on the breaker. The oven unlocked and appears fine now.
Nov 09, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Oven beeping, door locked F9 error
Have you tried to unplug the range for 5 minutes? That may reset the programming that is going on.
Nov 18, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Frigidaire FEF352 Electric Kitchen Range Logo
264 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
