Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Will turn on after many attempts
My TV will only turn on after many attempts with either the remote or the button on the front.
  • Anonymous Mar 27, 2008
    Same problem tried display, channel,5 volume (-) and power TV self diagnose came on but could not get this off screen.
    Was going to leave on and control by cable box
  • 129 Answers
Good day. There may have been some loose contacts particularly in the system IC. Have it resoldered.
chris
Posted on Mar 28, 2008
SOURCE:
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Dec 10, 2012 | RCA 20V500T 20" TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
When turning on the t.v. makes a clicking sound (Normal sound) but the t.v. doesn't turn on, no picture?I am wondering if the t.v. has a reset button or something?
Does any indicator light in front of the TV when you turn it on?
if the answer is yes, try turning on the TV by using the remote control. press any of the programme numbers 1-9 while pointing the remote at the TV. It is advisable that you install new batteries in the remote before attempting this.
If the answer is no then you should do the following:
- check the wall socket. try plugging another device into this socket to see if there is power present
if all the above fail thentake the TV to the repairman.
Oct 02, 2009 | Televison & Video
Tv keypad on front is locked and can't find remote
after reading a similar issue on fixya about another person having a similar problem and holding down the setup button for 10 seconds, I tried it on my television (although I don't have a setup only a menu button) and it worked. Thanks.
Jan 13, 2009 | Televison & Video
Sound goes down
The down button on your remote might be stuck down. Try taking the remote out of the room or cover it up with something. Then turn the sound up at the set and see if it stays up. If this doesn't work, the down button on the front of the set may be stuck or have leakage in the button. This would require taking the set to a service shop. Another possibility would be a loose ground on the CRT dag which can cause this. this also would be something a service shop would need to take care of, as you could get a shock if you attempt this repair yourself.
Nov 04, 2008 | RCA F36650 36" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
May 25, 2007 | Panasonic CT-32HX40 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
